Supernova HID Kits for your headlights/fogs Exclusive E60 Forum Offer
Old May 20, 2009 | 03:01 PM
  #31
Gene's Avatar
ordered
Old May 21, 2009 | 08:23 AM
  #32
energia's Avatar
thank you sorry i got it out so soon
Old May 21, 2009 | 09:37 AM
  #33
Gene's Avatar
, it's not a bad thing....thank you
Old May 22, 2009 | 08:48 AM
  #34
DRANGED's Avatar
Guys, so far the one member that has installed a set is having problems with these HID's. Member with the problem, could you please chime in?
I have yet to install mine but should have time this weekend and will report back as to my experience.
Old May 22, 2009 | 10:00 AM
  #35
energia's Avatar
i will make sure you are 100% satisifed.
member having problems will ship it back and let me test it. i pay return shipping.
i want good quality at low price so no worry on quality.
if it was a bad kit, supernova will cover cost for it and help us replace it for you.
please go ahead and install and test.
Old May 22, 2009 | 10:15 AM
  #36
AKAlius's Avatar
Alright, I did not want to write a review yet untill the issue comes to the final state and conclusion. As of now, The 3000K gold kelvin that I requested seems to be 4300K instead. I was told to let it burn in, but after an hours of burning in it still seemed to be 4300K which is stock color hue, not gold. One side seats perfectly in it housing the other side refuses to fully seat. There are three locking points on the bulb that allows the bulb to lock in posistion. Only 2 of the tree locking tabs seat. This is the only way it will seat. I know the the housing for the bulb is not defective as the OEM bulb will fully seat/unseat perfectly fine and smoothly, as it should.
With my car in idle, I get slight fliclkering. Once in motion, the flickering turns to strobing, then the side with the partially seated bulb turns off. I do not know if the partially seated bulb is causing the flickering, but I dont see why this would cause the flicker to occur.
I'm led to believe that the flicker is caused by one of the two:
A) Defective Ballast
Defective Bulb
To continue. Now, I think that I may have received two different bulbs as one was marked with a manufacture label and the other was not marked at all. i beleive that the one that was not marked, was the one that was defective.
Energia, I know that this was not your intention to send me a faulty product, but I do hope we can get this resolved as soon as possible. You did reply to my PM asking me if the flickering is in idle or in motion, and you did mention that if it was in motion then it was a faulty ballast. Also, you said that if it was the ballast then you will send me a different one to try to resolve this problem that Im having. I do appreciate that gesture, but I think if you do replace this kit for me then I would rather get a kit that has been tested before you send it to me.
Again, I applogize for your troubles and I hope this can be resolved as quickly as possible so that I can give your product a good review.
Thanks.
Old May 22, 2009 | 10:36 AM
  #37
energia's Avatar
of course customer service is very important
i will work with you and the supernova people to fix all your issues
i want happy customers at low price.
thank you for your confidence to let me resolve this for you.
Old May 22, 2009 | 01:27 PM
  #38
AKAlius's Avatar
Thanks energia for looking into this for me, and also the customer suppport that follows your sold kits. I will send back the kit for your testing tomorrow morning. Once I install the replacment kit I will give you your well deserved review.
Thanks!
Old May 22, 2009 | 06:30 PM
  #39
AKAlius's Avatar
Okay, so before fully uninstalling my HID's I compared both bulbs to one another. I was trying to see what allowed one bulb to seat and the other from seating fully. I realized that one of the gaskets around the HID bulbs was red and larger then the other HID bulb that seated correctly. The one that seated correctly was a yellow gasket, matching my OEM bulbs gasket exactly by color and size. I then tried to install the HID bulb that seated correctly into the other sides housing where I was having fitment issues. The HID bulb fit perfectly fine. This made me realize that for sure there was no issue with the housing, but the issue was with the bulb with the larger red gasket. I then proceeded to swap out the large red gasket with one of my OEM bulbs gasket and voila! It seated as it should. After I got both HID bulbs to fully seat, the flickering ceased and the true color revealed itself to be what I wanted, TRUE 3000K Super Gold color.
I am extremely satisfied with my 3000K SuperNova HID kit! It looks amazing. Super bright and very crisp color as I wished.
PROPS to energia for the excellent customer service and his low cost HID kits!!!
Now for the pics...
Heres the two gaskets. One yellow and the other that gave me fitment issue was red. You can clearly see the size difference.
Supernova HID Kits for your headlights/fogs Exclusive E60 Forum Offer -rubber_gasket.jpg
Heres the pics of the HID's Installed glowing bright.
Supernova HID Kits for your headlights/fogs Exclusive E60 Forum Offer -photo1.jpg
Supernova HID Kits for your headlights/fogs Exclusive E60 Forum Offer -photo2.jpg
Supernova HID Kits for your headlights/fogs Exclusive E60 Forum Offer -photo3.jpg
Supernova HID Kits for your headlights/fogs Exclusive E60 Forum Offer -photo4.jpg
Supernova HID Kits for your headlights/fogs Exclusive E60 Forum Offer -photo5.jpg
Supernova HID Kits for your headlights/fogs Exclusive E60 Forum Offer -photo6.jpg
Supernova HID Kits for your headlights/fogs Exclusive E60 Forum Offer -photo7.jpg
Supernova HID Kits for your headlights/fogs Exclusive E60 Forum Offer -photo8.jpg
THANKS ENERGIA!!!
Old May 22, 2009 | 06:37 PM
  #40
Gene's Avatar
^nice Phi, received my set today, will install sometime tomorrow. My h8 size bulbs does not have those gasket rings, so hopefully things should go smoothy
