RPI Power [UPDATED]
Old 11-07-2008, 07:52 AM
  #121
stylezzza's Avatar
My Ride: 2010 Audi S4
Originally Posted by joet@raceprecision.com' post='714716' date='Nov 7 2008, 03:25 AM
V1 and V2 scoop are not different in their functional design. The mounting of the V2 for the 550i is the only difference.
I thought the only reason why RPI is making a V2 is because of the bad fitment mounting and that goes for all 550s, 545s including 530s and as far as I know some of us had to custom fit tapes/metal/home depot supplies just to close the opening gaps that were losing air, if your not making a V2 for 530s then can you make a V3 for us? The fitment is slightly off
stylezzza is offline
Old 11-07-2008, 10:45 AM
  #122
mrfva's Avatar
My Ride: .
Model Year: .
How is the fitment slightly off? Do you have pics?
mrfva is offline
Old 11-07-2008, 11:14 AM
  #123
joe@raceprecision's Avatar
The 550i is the only model thus far that is having problems with mounting. Navin's 545i produced power with the original mounting. We are still in need of a 6speed or SMG 530i in for some dyno runs and based on the runs will have an idea whether V2 is necessary for the 530i.
joe@raceprecision is offline
Old 11-07-2008, 11:57 AM
  #124
Originally Posted by Steveadp' post='714916' date='Nov 7 2008, 08:48 AM
sent you a PM.
email replied
info@trinityautosport is offline
Old 11-07-2008, 12:18 PM
  #125
stylezzza's Avatar
Originally Posted by joet@raceprecision.com' post='715144' date='Nov 7 2008, 03:14 PM
All orders were put on hold until it was confirmed that V1 for the 545i made horsepower. We would still like to have a 6speed or SMG 530i in for accurate dyno numbers. NeRwEEzy's Steptronic 530i dyno graph, if I recall, did not show any gains. Now, would you like for us to sell you a product that hasn't been verified to produce power?
thank you, hope you understand why I'm so concerned I mean who would pay 99$ for something that does nothing? For looks? If that's the case I would go ahead and buy a AFE HAI for the sound you know what I'm saying? And I've been told it improves hp for the 530 so that's why I purchased it and again thank you for understanding, hope you find a manual 530 soon!
Old 11-07-2008, 12:36 PM
  #126
stylezzza's Avatar
no I currently do not have pictures but if you like I can take some tonight.
The fitment is off because the lines don't matchup so there are gaps in between
You can also check this thread out http://forums.e60.net/index.php?showtopic=63639&st=0
Correct me if I'm wrong but isn't the 545s intake vent/hole the same as 530s? The lines are same no? Well either way I have gaps in between
Old 11-07-2008, 12:43 PM
  #127
NextLevel530xi's Avatar
This was the first time reading this thread...From what I understand is that the scoop which I purchased for my 07 530xi and recieved does abosolutely nothing in HP gains??? Rather a piece or frabicated metal attatched to my car?
NextLevel530xi is offline
Old 11-07-2008, 12:56 PM
  #128
stylezzza's Avatar
and this is why I'm so concerned, I was told from the very beginning that it shows gains for the 530 from a very reputable vendor, if I was informed that they were still testing the scoops for the 530 then I wouldve waited.
Old 11-07-2008, 02:15 PM
  #129
NeRwEEzy's STEPTRONIC 530i was one sample. This particular sample did not result in any gains on the dyno due to the automatic kickdown and upshift of the STEPTRONIC, thereby giving us inconclusive results. This is why we need a 6speed or SMG 530i in for more sampling to gain a precise reading on the dyno. The 6speed and SMG do not kick down nor upshift at WOT. As for the design of the scoop, its proven to produce power. There are multiple dyno graphs with the M5s, ICEMAN316's 550i, and Navin's 545i as evidence. The same scoop will make power for the 530i, it just needs to be verified.
Old 11-07-2008, 09:18 PM
  #130
Originally Posted by joet@raceprecision.com' post='715316' date='Nov 7 2008, 03:15 PM
this is correct guys. my dynos before kept showing gains and losses alternating each time as the transmission kept kicking down. I believe Joe, member fantastic5, went with the scoop after I posted about it that a manual transmission was needed and his dynos showed gain.
Quick Reply: RPI Power [UPDATED]
