ModBargains | BMS Powerbox
My Ride: E30 325e & E46 ZHP Vert
More Horsepower, Torque, and better throttle response!!!
The BMS Power Box remaps the throttle mapping for better throttle response, and an increase in horsepower and torque. The Power Box features easy installation and removal, and gas pedal switching between 7 performance maps. The Power Box shows power gains from 8-10 horsepower and 8-10 Ft./Lbs. of torque at the rear wheels on a dyno. Upgrade your vehicle's power and drivability with the BMS Power Box.
The BMS Power Box is purely plug and play and installation only takes roughly 20 minutes, and only requires basic hand tools. It is completely reversible, and no cutting of any wires is needed. Installation is very discreet and allows most customers to leave the Power Box installed for routine service.
Benefits & Features
Applications (US Models)
Kevin
Benefits & Features
- 100% Plug and play
- Gains of 8-10 horsepower & 8-10 Ft./Lbs of torque at the rear wheels
- 7 available maps
- Easy switching of maps can be changed from the drivers seat
- Improved throttle response
- Compatible with both N51 & N52 motors
- E60/E61 528i/528xi
- E60/E61 525i/525xi
- E63/E64 630i
- E65/E66 730i
- E60/E61 523i
Kevin
Um, how much? (someone didn't read the vendor sticky)
I may be interested but BMS website has it listed for $279 - what is your price?
https://5series.net/forums/topic/658...o-all-vendors/
I have a question. Aren't BMW now able able to detect any remapping now some how? I go to SANTA MONICA BMW. any thoughts guys?
Quick question as well, I have a Velocity Booster would I be able to switch the booster off on the Box and just use the Velocity booster and use the ECU remap. Or is it better to just forget the Velocity Booster because I am not sure if they would interfere at all with each other, but I do like the easy adjustable response on the Velocity booster that is why I am debating it... I have a 2008 528i just in case.
My Ride: 2006 titanium silver metallic
Like new 41k
Cold Weather Package
I had my whole car programmed for my aux input, they couldn't see the powerbox and everything worked fine afterward. I would not recommend using this with velocity, it does the same thing just has power as well as remapping. It's really easy to change maps with the gas peddle I would say that is a non issue. I highly recommend this mod, I'm very happy with mine!
