Jlevi SW | StopTech Stainless Steel Brake Lines
Old Jun 11, 2010 | 11:02 AM
Cal@Jlevi SW's Avatar
FRONT- $69
REAR- $61
StopTech stainless steel brake lines improve pedal feel and reduce the amount of time between applied pedal pressure and actual deceleration by preventing expansion, which stock rubber flex lines allow. This provides a quicker pedal response, and allows the driver to maintain consistent brake pressure and precision brake modulation.
StopTech brake lines feature:
  • Teflon¨ inner lining
  • Outer layer of stainless steel woven braid
  • Teflon tube is very resistant to expansion under pressure
  • Will not degrade from exposure to brake fluid
  • Stainless steel braid provides support for the Teflon
  • Extremely durable weave withstands incidental impact and abrasion
  • Clear Abrasion Resistant Cover for maximum protection against chaffing
  • DOT (United States Department of Transportation) compliant
  • 100% tested to a pressure of 4500 psi
PelicanParts.com
Aug 14, 2015 10:15 AM
PelicanParts.com
Aug 13, 2015 01:45 PM
PelicanParts.com
Jul 23, 2015 12:50 PM
SayeedA
Jul 16, 2015 06:57 PM
PelicanParts.com
Jul 16, 2015 01:12 PM
