Jlevi SW | StopTech SportStop & PowerSlot Braking Rotors For E60
Old Jun 17, 2010 | 08:55 AM
Cal@Jlevi SW's Avatar
StopTech SportStop Rotors for all E60, E63, & E64 [STS-46]
Starting at $550 for full F&R set, please see link to website for more detailed pricing
StopTech SportStop rotors are a great first upgrade for the original brake systems of cars and trucks. SportStop one-piece direct replacement brake rotors fit stock calipers. The internal vane structure is identical to stock rotors. Quality is assured as the rotors are manufactured to meet or exceed all OE specifications.
StopTech SportStop Replacement Rotors Feature:
  • Drilled and/or slotted to wipe away debris and cool more effectively
  • More "bite" and less fade than stock rotors
  • Direct replacement, stock-sized rotors
  • Improved wet weather response
  • Reduced brake pad glazing
  • OE vane designs
  • Machining designs engineered for optimal rotor integrity
  • Double-disc ground for a consistent friction surface and better pad bed-in
  • Mill-balanced for vibration-free performance
  • Black e-coating on non-friction surfaces provides lasting, attractive looks
  • Enhances open wheel appearance
Old Jul 8, 2010 | 09:03 PM
All PMs replied. Thank you guys for your continued support.
kongse
Jul 17, 2015 03:29 PM
TexaZ3
May 6, 2015 09:54 AM
addy33
Apr 13, 2015 04:40 AM
ZeZe
Oct 15, 2003 12:58 PM
