Jlevi SW | RDSport Sway Bars for the E60/E61
cal@jlevisw.com | 1.888.JLEVISW | JleviSW | Your #1 Source for High-End BMW Enhancements
RDSport Sway Bars for the E60, E61, E63 & E64 [196 81 60 100]
$620.00
RDSport's lightweight hollow sway bars weigh in at 8.5lbs each, and are adjustable to be between 16 and 33% stiffer than the factory sway bars. These sway bars not only increase the overall spring rate to reduce body roll at any setting, but are also adjustable for the rate of spring rate increase, and will yield much more aggressive handling response. By enabling the driver to change the rate of increase of the swaybar stiffness, RDSport swaybars will help tune out understeer on initial turn in.
Fits all E60, E61, E63, and E64 BMWs excluding M5 and M6
RDSport Sway Bars Feature:
- * 27mm Front Bar Thickness
- * 19mm Rear Bar Thickness
- * Increased Stiffness and Handling
- * Replacement Urethane Bushings
- * Lightweight Hollow Construction
- * RD Green Powder Coat Finish
- * Requires M5 Bushing Holders
A must have for any track enthusiast.
![](http://www.jlevistreetwerks.com/images/E9X_M3_swaybars.jpg)
My Ride: '07 530iSport PackageLuxury Packagemore to come
I had RD sway bars on my E36 M3 and they sure did improve the handling on that car. Would these do anything better than the Active Roll system in the E60?
Hi guys,
thanks for your interest.
Unfortunately these sway bars does not work with cars equipped with ARS or 4WD/XI Models.
On another note, the required "m5 bushing holders" is the following OEM part
Front STABILIZER SUPPORT - 31352283190 - 2X FRONT REQUIRED.
DetailersDomain
Detailing Forum
09-22-2015 03:59 PM
umnitza
09-02-2015 11:28 AM
