cal@jlevisw.com | 1.888.JLEVISW | JleviSW | Your #1 Source for High-End BMW Enhancements RDSport Sway Bars for the E60, E61, E63 & E64 [196 81 60 100] $620.00 RDSport's lightweight hollow sway bars weigh in at 8.5lbs each, and are adjustable to be between 16 and 33% stiffer than the factory sway bars. These sway bars not only increase the overall spring rate to reduce body roll at any setting, but are also adjustable for the rate of spring rate increase, and will yield much more aggressive handling response. By enabling the driver to change the rate of increase of the swaybar stiffness, RDSport swaybars will help tune out understeer on initial turn in. Fits all E60, E61, E63, and E64 BMWs excluding M5 and M6 RDSport Sway Bars Feature:
A must have for any track enthusiast. |
Green! Do they come with other color options?
No unfortunately, RD Sport green is traditional color for their cars/products.
I had RD sway bars on my E36 M3 and they sure did improve the handling on that car. Would these do anything better than the Active Roll system in the E60?
Xi fitment?
Hi guys,
thanks for your interest. Unfortunately these sway bars does not work with cars equipped with ARS or 4WD/XI Models. On another note, the required "m5 bushing holders" is the following OEM part Front STABILIZER SUPPORT - 31352283190 - 2X FRONT REQUIRED. |
