Jlevi SW | B&G S2 Lowering Springs for the E60
cal@jlevisw.com | 1.888.JLEVISW | JleviSW | Your #1 Source for High-End BMW Enhancements
B&G S2 Lowering Springs - E60 [BG-E60]
Drawing on over 150 years of spring design and manufacturing expertise, B&G S2 Sport Springs are engineered to improve handling while maintaining safety and ride quality.
By redesigning the O.E. Spring and the lowering the center of gravity from 1-2.5" (depending on vehicle and application) B&G technicians dramatically improve your vehicles performance and appearance. Incorporating a progressive rate design allows B&G Springs to offer higher rates for improved road hold, while maintaining a comfortable ride
B&G S2 Springs Feature:
- Cold wound from high tensile chromium silicone wire
- Individually super blocked
- Computer tested against tight tolerances
- ISO9001, QS1400, and TUV Ceritfied!!
- Progressive rate design
- Higher rate design for improved road hold
- Maintains comfortable ride
- Limited Lifetime Warranty
525, 530i Sedan [08.1.160]
(2004-2009)
Lowers Vehicle 1.2" front, 1.2" rear $244.30
545i, 550i Sedan [08.1.162]
(2004-2009)
M5 [08.1.168]
(2006-2009)
Lowers Vehicle 1" front, 0.5" rear $258.30
Hi,
unfortunately it will not work with cars with self-leveling suspension...
For cars with self-leveling suspension, I believe BMW can actually lower by just dialing it in with their computer. The front springs should work just fine, however.
Thanks for your interest.
Kasmo
Aug 10, 2015 12:12 PM
laz1left
Mar 9, 2015 01:54 PM
