Jlevi SW | Bavarian Technic BT Cable OBDII Diagnostic Tool
Old Apr 21, 2010 | 12:12 PM
Cal@Jlevi SW's Avatar
Enthusiast Version - 3 VINs [BTENTHUSIAST] $287.00
Pro Version - Unlimited VINs [BTPRO] $675.00
Read & Reset your check engine, airbag and fault codes without costly BMW dealer visits!
Compatible with all 2001-2010 BMWs. Single VIN version is availble only with a JB+ or JB3 product.
A true "game changing" product, the Bavarian Technic BT Cable does everything a GT1/OPS system can and much more for a fraction of the price, including reading/deleting extended codes, check engine light reset, tuner detection codes, and airbag light reset/codes. It also performs high speed data logging of over 600 parameters including knock ******, adaptation values, O2 sensors, boost targets, etc.
Bavarian Technic cable works on Engine, Airbag, ABS, Transmission, OEM BMW Alarm, Central electronics, Heating & A/C,And much more...
Plugs directly into your factory OBDII diagnostic port under your dash on the drivers side.
Our hardware solution consists of an adapter cable which has one end that plugs into the USB port of a laptop or desktop computer and another end that plugs into the OBDII diagnostic port of your car. Since our hardware supports USB it is compatible with most computers.
What can it do?
  • The tool accesses the electronic control units in your BMW to:
  • Read and clear diagnostic fault codes
  • Display shadow faults and soft faults
  • Display and record real-time actual values
  • Activate components of the car for troubleshooting
  • Reset service reminders
  • Reset condition-based service indicators
  • Send special commands to control units
  • Show ECU information
  • Access the latest BMW DCAN systems for 2007+ models
Old Apr 21, 2010 | 12:30 PM
aresh's Avatar
wow this is very cool, what does the unlimited vin mean? Someone should get this around NY and then i can pay them to reset the airbag warning
Old Apr 21, 2010 | 03:58 PM
Unlimited VINs means it can be used on unlimited cars, the enthusiast version is limited to 3 cars.
Old Apr 21, 2010 | 05:52 PM
D33ZNUT5's Avatar
My Ride: 2006 titanium silver metallic Like new 41k Cold Weather Package
Can you use this to enable mp3, program for ipod, aux input, drl's etc?
Old Apr 22, 2010 | 09:01 AM
Please refer to the chart in the following link..
http://www.bavariantechnic.com/model...trix.aspx#e60a
Thanks!
Old Apr 27, 2010 | 09:23 AM
525iEnjoy's Avatar
This would be a nice addition hmmm...I'll let you know
spykes
Nov 26, 2015 09:58 PM
hmilycar
Jul 31, 2015 10:07 AM
Kbc
Jul 27, 2015 05:51 PM
ferrary01
Jul 9, 2015 12:38 PM
hmilycar
Jul 7, 2015 12:29 PM
