Its time for World famous best brake systems by BREMBO
My Ride: BMW 2005 X3 3.0
SERIOUS INQUIRES PLEASE
Please PM for pricing with your country name or USA zip codes
The Brembo Gran Turismo High Performance Braking System offers significant advantages over the OE manufacturer's system ? advantages far beyond what's simply known as "big brakes". As the braking system's primary function is to dissipate heat, larger, more sophisticated discs are used in order to increase the fade resistance of the system. These discs are directionally vented for enhanced cooling, as well as drilled or slotted for improved consistency, continuously cleaning and refreshing the pad surface.
In most applications, a two-piece "floating" disc assembly is used, with a cast?iron disc specially mounted to a billet aluminum hat. One of the advantages of this type of construction is reduced weight. By making the center-section of the disc out of aluminum, a great deal of weight can be saved in a key location, as it is both unsprung and rotating. The greatest advantage, however, lies in the float itself. The brake discs must cope with extreme temperature levels. In the case of a non-floating disc, thermal stresses develop which lead to warping of the disc and cupping of the braking surface. With the full floating system, the disc is free to grow relative to the bell, and can remain straight and true.
On nearly all the vehicles for which there is a Gran Turismo system available, the OEM caliper is of a sliding design, with the piston or pistons on only the inboard side of the disc. While this type of caliper is inexpensive to manufacture, it is generally extremely heavy, and inherently flexible, both of which are to be avoided on a performance braking system. Conversely, Brembo's calipers are fixed mount, opposed piston calipers cast from aluminum alloy. Despite being much larger and many times stiffer than the original caliper, they are also much lighter. The calipers are equipped with differential piston bores in order to eliminate pad taper. Without this feature, the leading edge of the pad will wear more quickly. This can cause problems such as cocking the pistons in their bores, which can damage or seize them.
Each Gran Turismo system comes with high performance brake pads, aircraft quality hardware, DOT and T?V? approved Goodridge stainless steel braided brake lines, instruction manual and dye cut stickers for your car.
The net result is a braking system, developed specifically for each vehicle application by Brembo's immense technical resources, that insures high quality as well as high performance.
High Performance Friction Material:
Aggressive pads that provide the highest level of performance.
Cross-Drilled or Slotted Discs:
Clears gasses, cleans pads for better "bite".
Mounting Brackets and Assembly Hardware:
Aircraft quality included and pre-torqued specifications.
Goodridge Stainless Steel Braided Brake Line:
DOT/T?V approved.
Multi-Use Street, Performance Driving, Track Events Derived from Race-Based Components:
Increased stopping on the street, at drivers' schools and at club events with proven on-track performance at the highest evels of racing.
"Floating" Disc Mounting System with Billet Aluminum Hat:
Reduce "Unsprung Weight" for better handling and reduces heat-related stress; increases brake performance and pedal feel.
Four or Eight Piston Cast Aluminum Calipers:
Provide maximum braking force without the flex of sliding calipers.
I am quite interested in these brakes, however, I think I should wait until after the free maintenance warranty is up as I don't think BMW would replace any of the brake parts if they were Brembo's. I will contact you after the maintenance portion of my warranty has expired. Thank you for the posting.
yes sir good idea.please let me know when you are ready.
best regards,
Tony
My Ride: 2006 525i Silver Gray/Gray Dakota Leather | Steptronic | Cold Weather | Xenon | Premium Package
Modifications:
M Aero Kit | Carbon Fiber Kidney Grill | K&N Air Filter | Charcoal Filter Removed | Radenergie R10 Silver 20" soon | kW coilover V3 | SprintBooster soon | M5 trunk finisher
Next planned mods:
?Hamann quad exhaust + Hamann quad rear diffuser + Hamann Front Lip?
I might be looking into this once my current brakes have worn out
12-14k more miles to go..
and you can install them and take off whenever the car is sold or given back to the lease.
most importantly, they really dont lose their value too much for resale..
thanks.
tony
Originally Posted by my530i' post='365345' date='Dec 9 2006, 10:41 AM
Tony,
I'd suggest you to promote both M5 and BBK
once its done by someone from here I will promote them for sure
Modifications:
Next planned mods:
Hey Tony, do you have stoptech as well?
