High Powered LEDs (19 Piece Setup) $80.00
Old Nov 22, 2009 | 07:59 PM
khoalty's Avatar
My Ride: BMWs
For pictures:
https://5series.net/forums/index.php...opic=89293&hl=
I have the following that will be included in the setup.
Driver foot well
Passenger footwell
Driver vanity
passenger vanity
Glovebox
trunk
front dome (high powered panel in the centerdome)
rear dome (high powered panel in the centerdome)
puddle lamps on door bottoms (directional bulbs)
license plate bulbs
Any interest? This is alot cheaper than if you were to piece them separately. It will be 80 plus shipping. Shipping charges are via Fedex Ground, it won't be much and very reasonable for what it is.
Old Nov 23, 2009 | 09:15 AM
Da_Meister_22's Avatar
My Ride: M5
Model Year: 2013
Engine: S63
I already have the center front and back dome LEDS, and the License Plate. But I need all the other ones, would it be cheaper?? And do I need resistors??
Old Nov 23, 2009 | 04:04 PM
cleung's Avatar
Welcome back Khoa, guys Khoa is a stand up vendor I have been buying from him for a while now and have always had good customer service. Buy with confidence.
Old Nov 23, 2009 | 04:18 PM
khoalty's Avatar
My Ride: BMWs
No resistors are needed on these at all.
With the front and back center domes, it is best to go with the panels as they give enough light as well as power so the idrive does not give you problems.
I try to keep the pricing with the least amount of mark up as possible
You can order the rest of the bulbs separately from
www.khoalty.com/LED.html
Old Nov 24, 2009 | 08:06 AM
jas_r_1's Avatar
My Ride: 2006 520d - 19" 172s- Remapped - LCI taillights V6 cables - LCI xenon headlights - Denison 500 with BTA1500 - led interior lights - OEM led number plate lights Planned mods: Folding mirrors - Modmynav kit - High gloss shadowline trim -
How bright are these and does the light cone out blue or White? Also, do these throw up any error msg's or strobing/flickering?
Thanks
Jas
Old Nov 24, 2009 | 06:02 PM
cleung's Avatar
Thanks
Jas
The LED panels for the front and rear dome are insane bright and the color is about 6000k color (cool white). The interiors do not flicker on startup, I'm not sure about the LED plate lights because I'm always inside the car starting it then going out to look. I bought the panels and license plate LED's from khoa a few weeks ago and so far I love them.
Old Nov 24, 2009 | 06:10 PM
khoalty's Avatar
My Ride: BMWs
Thanks
Jas
These don't flicker nor do they strobe. The panels that are for your center dome lights are enough where you don't need to add in resistors. Most LED kits when you start your engine you can not turn on your lights when the car is on bc it doesn't take up enough power.
These come out white and they are fairly bright, very comparable to the oem halogen bulbs.
Old Nov 24, 2009 | 07:55 PM
My Ride: M5
Model Year: 2013
Engine: S63
I need Trunk, reverse, foot rest, door bottoms, map lights (4x). Can you tell me which light model # I need for each, so I can order the right ones from your web site.
Old Nov 26, 2009 | 11:41 PM
jas_r_1's Avatar
How to ship to UK and can you breakdown how many bulbs are required in which area?
Old Nov 27, 2009 | 05:32 PM
cleung's Avatar
trunk light are the 39mm festoon, reverse I would buy a pair of the panels and then a pair of the big resistors, foot rest is 39mm festoon, door bottoms is 194 wedges, map lights also the 194 wedges.
