High-Powered LED license plate lights
Old Jan 13, 2009 | 08:00 AM
Howitzer's Avatar
How do these install? Any DIY's?
Old Jan 13, 2009 | 08:07 AM
Gene's Avatar
just a bulb swap ...all you have to do is follow the instructions in your manual
Old Jan 13, 2009 | 08:11 AM
Mike@F1 Autohaüs's Avatar
Originally Posted by C's Bimmer' post='766453
Are these guaranteed error-free on a LCI?
If you leave your lights on auto, it will pop-up an error upon start up but clears immediately
Simply push and slide out your existing license plate housing and replace the bulb with the LED
Let me know if you guys have any other Qs
Old Jan 13, 2009 | 08:17 AM
Gene's Avatar
Originally Posted by Mike@F1 Autoha?s' post='766777' date='Jan 13 2009, 09:11 AM
These are 2x brighter that than the OEM LEDs since each festoon has 2 High-Powered LEDs with 6 chips per LED
***will the bulbs also strobe at start up if lights are left in the auto position?
Old Jan 13, 2009 | 09:00 AM
There is no strobing whatsoever when I installed them. I will double check for you later this evening w/ the pics installed on a 545i as well
Old Jan 13, 2009 | 09:42 AM
radzM's Avatar
Is this for pre-lci also?
Old Jan 13, 2009 | 10:29 AM
Howitzer's Avatar
Great question.
Old Jan 13, 2009 | 10:56 AM
These are replacement LEDs for the pre-LCI models.
Old Jan 13, 2009 | 04:25 PM
Didn't have the tripod with me and my arthritis was kicking in. Here the the pics installed on a dusty Carbon Black 545i:
Some distance:
Close up:
Ground shot of output:
Let me know if y'all have any other Qs
Old Jan 13, 2009 | 04:29 PM
E60 545i SPORT's Avatar
My Ride: AW E46 M3 Vert
those look good.
