F1 Autohaüs | Premium Performance Stage 2 Upgrade Brake Kit
My Ride: 2005 330I ZHP
F1 Autoha?s | Premium Performance Stage 2 Upgrade Brake Kit
For E60 Auto 525i
Premium Centric Front and Rear Slotted, Cross-Drilled or Both Rotors
Axxis Front and Rear Ceramics Pads*
Stoptech Front and Rear Stainless Steel Brake Lines
3 - Motul RBF 600 Performance Brake Fluids
Centric Front and Rear Brake Pad Wear Sensor
For A GRAND TOTAL OF $725/Set
For E60 Manual 525i
For A GRAND TOTAL OF $800/Set
For E60 528i/xi
For E60 530i
For E60 535i/xi
For A GRAND TOTAL OF $775/Set
For E60 545i/550i
For A GRAND TOTAL OF $810/Set
For E60 Auto 525i
For E60 Manual 525i
For E60 528i/xi
For E60 530i
For E60 535i/xi
For E60 545i/550i
More Info on the Products:
Premium Series Performance Rotors provide unmatched performance and style. More than just a drilled and slotted rotor - our Premium Series start with special castings and are machined to provide increased performance and reliability over OE rotors. Faster stops, smoother performance, and increased reliability are what you get from our Premium Rotors - and styling that will turn heads.
Features:
Double Drilled and Staggered Holes
Exclusive Diamond Slots
Super Accurate CNC Computer Machining
All Holes Chamfered
Stronger Castings with Premium Iron and Double Disc Grinding
Black Electro-Coated Finish
Benefits:
Faster Stopping From Super Efficient Design
Reduce or Eliminates Warping for Smoother Operation
No Modification Needed - OEM Direct Replacement
Even Heat Transfer for Faster Heat Dissipation
100% Mill Balanced for Consistency, Reliability and Smoothness
(Note: Centric is the parent company of StopTech and Power Slot. StopTech SportStop and Power Slot rotors start as Centric blanks and are machined in-house on computer controlled milling machines.)
Thanks Again,
Anthony
Glowin
04-13-2015 02:42 PM
carid
03-06-2015 04:58 AM
