F1 Autoha?s | Premium Performance Stage 2 Upgrade Brake Kit https://i738.photobucket.com/albums/...erformance.jpg For E60 Auto 525i Premium Centric Front and Rear Slotted, Cross-Drilled or Both Rotors Axxis Front and Rear Ceramics Pads* Stoptech Front and Rear Stainless Steel Brake Lines 3 - Motul RBF 600 Performance Brake Fluids Centric Front and Rear Brake Pad Wear Sensor For A GRAND TOTAL OF $725/Set For E60 Manual 525i Premium Centric Front and Rear Slotted, Cross-Drilled or Both Rotors Axxis Front and Rear Ceramics Pads* Stoptech Front and Rear Stainless Steel Brake Lines 3 - Motul RBF 600 Performance Brake Fluids Centric Front and Rear Brake Pad Wear Sensor For A GRAND TOTAL OF $800/Set For E60 528i/xi Premium Centric Front and Rear Slotted, Cross-Drilled or Both Rotors Axxis Front and Rear Ceramics Pads* Stoptech Front and Rear Stainless Steel Brake Lines 3 - Motul RBF 600 Performance Brake Fluids Centric Front and Rear Brake Pad Wear Sensor For A GRAND TOTAL OF $725/Set For E60 530i Premium Centric Front and Rear Slotted, Cross-Drilled or Both Rotors Axxis Front and Rear Ceramics Pads* Stoptech Front and Rear Stainless Steel Brake Lines 3 - Motul RBF 600 Performance Brake Fluids Centric Front and Rear Brake Pad Wear Sensor For A GRAND TOTAL OF $725/Set For E60 535i/xi Premium Centric Front and Rear Slotted, Cross-Drilled or Both Rotors Axxis Front and Rear Ceramics Pads* Stoptech Front and Rear Stainless Steel Brake Lines 3 - Motul RBF 600 Performance Brake Fluids Centric Front and Rear Brake Pad Wear Sensor For A GRAND TOTAL OF $775/Set For E60 545i/550i Premium Centric Front and Rear Slotted, Cross-Drilled or Both Rotors Axxis Front and Rear Ceramics Pads* Stoptech Front and Rear Stainless Steel Brake Lines 3 - Motul RBF 600 Performance Brake Fluids Centric Front and Rear Brake Pad Wear Sensor For A GRAND TOTAL OF $810/Set More Info on the Products: Premium Series Performance Rotors provide unmatched performance and style. More than just a drilled and slotted rotor - our Premium Series start with special castings and are machined to provide increased performance and reliability over OE rotors. Faster stops, smoother performance, and increased reliability are what you get from our Premium Rotors - and styling that will turn heads. Features: Double Drilled and Staggered Holes Exclusive Diamond Slots Super Accurate CNC Computer Machining All Holes Chamfered Stronger Castings with Premium Iron and Double Disc Grinding Black Electro-Coated Finish Benefits: Faster Stopping From Super Efficient Design Reduce or Eliminates Warping for Smoother Operation No Modification Needed - OEM Direct Replacement Even Heat Transfer for Faster Heat Dissipation 100% Mill Balanced for Consistency, Reliability and Smoothness (Note: Centric is the parent company of StopTech and Power Slot. StopTech SportStop and Power Slot rotors start as Centric blanks and are machined in-house on computer controlled milling machines.) Thanks Again, Anthony |
