Cross Competition Coilovers
Old Jul 21, 2008 | 01:57 PM
ModBargains's Avatar
My Ride: E30 325e & E46 ZHP Vert
JIC Cross Competiton Coilovers
The ultimate coilover setup for your 'ULTIMATE DRIVING MACHINE,' Cross offers the bets with no compromises for your E60 with the Cross Competition Coilovers. Cross coilovers feature: pillow ball upper mounts, cool bend linear springs, high strength inverted monotube, helper spring, adjustable damping, durable monotube design, and an adjustable lower bracket. Based off of racing technology, the Cross Competition Series Coilover is a street performance suspension, customizable for full track use.
PILLOW BALL UPPER MOUNTS: Included for some vehicles for the front and some for rear depending on application. Adjustable camber plates also included for most vehicles front applications with MacPherson Strut suspension systems, some applications may come with a rubber bushing upper mount depending on application.
COOL BEND LINEAR SPRING: Linear (consistent spring rate) spring manufactured using chrome silicon metal alloy with a cool bend process to prevent sag or loss of spring rate. Each kit comes with various spring rates that are available for more of a custom set up.
HIGH STRENGTH INVERTED MONTOTUBE: This unique design features a 40 mm piston with a one of a kind bumpstop design incased inside the damper. The walls of the shock casing is lined with grease so that the absorber body can easily move along inside the shock casing body. There are also two thrust bearings to protect the absorber body.
HELPER SPRING: Select Cross Competition BMW coilovers come with helper springs to aid for street day to day driving. This also allows for a wider range of higher spring rates and for a smoother ride.
ADJUSTABLE DAMPENING: Available for all applications with 15 ways adjustability. With this feature, you are able to tune your suspension dampening up to your specifications and style of driving.
DURABLE MONOTUBE DESIGN: High pressure nitrogen gas filled monotube design with special stable viscosity index oil that will not be affected by wide temperature changes. Therefore, heat does not affect the performance capabilities. 40mm and 45mm pistons are used on certain applications.
ADJUSTABLE LOWER BRACKET: More durable than factory brackets with adjustable ride height ranging from 0.5" to 2.5" drop without sacrificing the suspension travel.
Detailed application guide can be seen in out listing HERE
525i, 530i, 535i, 540i
If you have any questions or comments, feel free to post here or CONTACT US!
If you would like to reach me personally, you can always PM me or contact me via e-mail at roge@modbargains.com.
Old Jul 21, 2008 | 02:59 PM
PMs replied guys!
Old Jul 22, 2008 | 10:01 PM
All PMs replied!
Old Jul 25, 2008 | 10:01 AM
PMs replied guys!
Old Jul 28, 2008 | 12:21 PM
All PMs replied folks!
Old Jul 28, 2008 | 06:27 PM
PMs replied everyone, thanks for the interest!
Old Jul 30, 2008 | 01:34 PM
PMs replied!
Old Aug 4, 2008 | 11:53 AM
Old Aug 7, 2008 | 11:41 AM
All PMs replied!
Old Aug 7, 2008 | 12:02 PM
John Photography's Avatar
does anyone have these installed? if so, pls chime in on your review....thoughts? concerns?
thanks.
