CampioniShop: AP Racing BBK upgrade
In continuing fashion, CampioniShop is proud to present to 5series.net the AP racing brake products. These F1 inspired brakes are great for scarce track usage, everyday driving and make for great show pieces!
?High-strength, lightweight pressure-cast aluminum alloy body
?2-piece caliper design for maximum rigidity in a streetable caliper
?6 pistons to minimize pad taper and maximize pad area
?Anti-knock back features for a consistent, firm pedal
?Directional curved vanes for maximum cooling.
?2-piece modular design with aluminum alloy hat to handle the heat.
?Cross-drilled AND slotted for aggressive pad bite and additional cooling.
Diameter: 14"
For the biggest brake system upgrade, look no further than world renowned AP Racing 6-piston calipers running on 2-piece rotors. Each kit is designed to work with the original equipment master cylinder, ABS and traction control systems. Specially-designed 2-piece rotors are cross-drilled and slotted, the optimum for high-performance street, autocross and occasional track day use. Slotted-only versions are available for the serious track enthusiast. The curved vane construction provides maximum cooling, while significantly reducing unsprung weight.
DOT-compliant and T?V-approved stainless steel lines are included to top off the upgrade and provide a huge improvement in pedal feel and stiffness. Brackets and hardware are made from aerospace-grade materials and high-strength fasteners. All AP Racing kits are complete with no other parts required. Install, bleed and go!
Put decades of championship-winning experience on your car. It's not just for Formula One and NASCAR winners anymore. Or LeMans, or British Touring Cars, or WRC, or Grand Am, or Super GT, or DTM...
Available with black or red calipers.
MSRP: 4280.24
5 series price: PM us
Diameter: 14"
MSRP: 4280.24
ucsbwsr
09-19-2015 10:58 AM
umnitza
09-02-2015 11:28 AM
Florida2002m3
09-01-2015 10:59 AM
