Bilstein PSS10 Coilovers
Old Oct 16, 2009 | 07:22 AM
wanker's Avatar
Silly question.... Would these coilovers work for a 2004 530i?
Most Bilstein websites only reference the PSS9 coilovers for that year and model.
Old Oct 16, 2009 | 10:16 AM
Nolan222's Avatar
I belive they will according to Turner motorsports
Bilstein PSS10 Coil Over Suspension for E60 5-series
Part #: GM5-D549
Applications: 2004 - - (E60)
Bilstein PSS10 coil over package combines improved cornering ability with super-cool looks to give you a superior suspension. This is a set of ride height adjustable and damping adjustable shocks and springs, developed by one of Germany's leading OEM manufacturers.
The PSS10 kit consists of monotube Bilstein dampers with a single adjustment knob on each shock. The knob controls the stiffness of the shock so you can set it at a soft setting for everyday use or dial in extra shock stiffness for autocross, track, or aggressive street carving. The knob is easily adjusted from the bottom of each strut/shock. The Bilstein monotube design is the latest innovative design from Bilstein and features a single, large piston that is lighter, more sensitive, and cooler than ordinary twin-tube shock designs.
Each shock is ride-height adjustable through a lower spring perch threaded on the shock body. The height can be adjusted through a range of one inch with the highest setting approx 1 inch lower than the stock ride height. The springs are progressive-rate with a softer rate at normal ride height that will get stiffer as the spring compresses. The result is a ride not much different than stock on regular pavement.
This suspension kit fits with the stock mounts in the front and in the rear. It is a direct bolt-in replacement for your stock shocks and springs. It fits all 2004 and later 525i, 530i, 535i, 545i, and 550i but will not fit any model with the factory self-leveling or EDC system.
Old Oct 16, 2009 | 03:10 PM
Jimmy @ Eurorev's Avatar
Part #: GM5-D549
Thanks Nolan.
Old Oct 16, 2009 | 04:03 PM
dbae1978's Avatar
Great installed or shipped price Jimmy! good luck with the sale. someone jump on these before it's too late
Old Oct 21, 2009 | 01:46 PM
Thanks David!
SOLD!
Old Oct 30, 2009 | 08:02 AM
broddews73's Avatar
My Ride: broddews73
Hey, would you be interested in a S5 TII transmission for the kyb springs and strut combo? If not, I will see what I can do next week. I am really interested in suspension.
Old Oct 30, 2009 | 05:59 PM
Ferdie's Avatar
^^ Hey Brod, the suspension is SOLD
Old Nov 11, 2009 | 10:16 PM
tongam's Avatar
How much if incl shipping to Indonesia (Jakarta city). Thx
Old Nov 11, 2009 | 10:35 PM
Ferdie's Avatar
^^ Hey Tong, the suspension is SOLD
Old Nov 11, 2009 | 10:58 PM
v_therussian's Avatar
Will it fit an Xi?
