-=EMS=- BMS JUICE BOX TUNES NEW LOW PRICE !!
FREE SHIPPING TILL JANUARY 1ST
JB Stage 1 $ 99
A lower boost version of the JB, offering 20-30 rear wheel horsepower and 30-40 rear wheel torque gains. Installation is slightly easier than the Stage 2, and peak boost is limited to 9.75 psi. Does not require solenoid bypass. This is how the car should have come from the factory!
JB Stage 2 $ 229
Our most popular tune, offering 40+ rear wheel horsepower and 50+ rear wheel torque gains on 91 octane, or 50+ rear wheel horsepower 60+ rear wheel torque gains on 93 octane when coupled with the hot pill. Peak boost is set at 11psi and tapers at high RPM for long compressor life, and air/fuel ratios are remapped for maximum performance.
JB Stage 3 - Professional / pin out harness $ 379
The latest generation of the Juice Box Performance Tuner features completely new microcontroller based hardware, numerous additional input/output channels, safety features, a plug and play wiring harness, and gains of up to 80 horsepower and 80 torque to the wheels on an otherwise stock car! Compatible with 29.2/v81 ECU.
*The pin-out (suggested for more experienced enthusiasts) uses OEM BMW pins in similar manner to JB1 and JB2, and has an install time of 30-45 minutes. Neither version requires the solenoid bypass or any vacuum line changes making removal a snap!
JB Stage 3 - Plug and play harness $ 629 ( On back order)
BMS single intake $ 129
Offering 8-15 rear wheel horsepower gains, the BMS intake replaces your restrictive factory airbox assembly with a custom built K&N brand filter. Features ~20% more filter surface area and much better sound than the factory airbox, all without raising your intake air temperatures. Fits BMW 135 / 335 / 535.
BMS dual cone intake $ 139
Prefer the look of a dual cone? Featuring quality S&B inverted cone filters our dual cone intake offers the highest possible flow in an attractive and easy to install package. Includes anodized black aluminum couplers and all required hardware. Fits BMW 135 / 335 / 535.
BMS modified Clutch Delay Valve $ 20
A must have for any stick shift, the BMS clutch valve replaces your factory clutch delay valve with a professionally ported valve. The result is quicker shifts, longer clutch life, and improved 0-60 times. Installs quickly and is visually identical to the factory valve. Fits BMW 128 / 135 / 328 / 335 equipped with manual transmission.
*not including shipping
Check out the site to order and more details
http://www.exquisitemotorsports.com/...lts.asp?Cat=63
JB Stage 1 $ 99
JB Stage 2 $ 229
^+2
also, is BMS's policy of free upgrade swaps still valid thru you....as advertisted via http://www.burgertuning.com/ "....We also offer an industry leading 100% trade up policy for customers who choose to upgrade to one of our more powerful tunes at a later time."
Ya know I looked for vendor fees or donations guess I did not look hard enough I will now though To answer your questions yes we do have free version upgrades from 90 days of purchase.
All v3 tunes are now shipping with the newest version 1.2
All tunes including PNP will ship right after the holidays.
Anything else just let me know
chadillac2000
42
09-13-2017 11:15 AM
chadillac2000
DIY: Do It Yourself
04-07-2017 04:31 PM
CertifiedOfficial
04-18-2015 12:11 AM
incoherent
04-15-2015 04:48 PM
