-=EMS=- BMS JUICE BOX 3 Pin-Out Lowest Price Ever!!
Old 12-24-2008 | 04:27 PM
Andrew@EMS's Avatar
Exquisite MotorSports is proud to announce the lowest price for jb3 pinouts ever!
The latest generation of the Juice Box Performance Tuner features completely new microcontroller based hardware, numerous additional input/output channels, safety features, and gains of up to 80 horsepower and 80 torque to the wheels on an otherwise stock car! Compatible with 29.2/v81 ECU.
All Tunes will be shipped with the new Ver. 1.2
Updates:
1) Gas pedal map switching. Allows you switch maps or disable the JB3 from inside the car without running any additional wires or having to carry around a keyfob. Intuitive to use.
2) A host of new maps, including maps with much improved low end reponse.
3) Numerous firmware changes to allow RS232 operation with our upcoming gauge / tuning tool and future software.
4) Improved digital signal filtering for smoother overall operation.
5) Map corrections to handle CELs that have cropped up in some cars during 30-40 degree ambient weather conditions.
Here is the new selection of user maps:
0 Stock/Valet
-- Stock tune with boost levels of 6-8psi
1 Low boost map
-- Boost levels of 11-12psi
2 High altitude map
-- Boost levels of 13-14psi but more aggressive high RPM boost taper
3 High boost map
-- Default map, suggested for most users
-- Auto detects and adapts to mods like race gas, intake, exhaust, DP, etc
4 High boost map with lagfix
-- Same as map 3 but with improved throttle response below 3500rpm
5 Hot map
-- Same as map 3 but with more aggressive low end boost and less high end taper
-- Suggested for those looking for a little more power than the high boost map
-- May trigger a soft code (CEL) from time to time if your car is not up to the task (plugs, fuel pump, fuel, etc)
6 Hot map with lagfix
-- Same as map 5 but with improved throttle response below 3500rpm
7 Race map (customer version)
-- 97+ RM/2 octane and supporting mods suggested
-- Peak boost of 14-16psi depending on mods and weather.
OUR PRICE $344 SHIPPED
WE HAVE A LIMITED SUPPLY OF ONLY 10 UNITS AND SALE ENDS JANUARY 4TH AT MIDNIGHT
*SHIPPING IS TO LOWER 48 STATES ONLY
chadillac2000
42
09-13-2017 12:15 PM
chadillac2000
DIY: Do It Yourself
04-07-2017 05:31 PM
OldSpool87
05-31-2015 10:04 AM
CertifiedOfficial
05-21-2015 01:42 AM
CertifiedOfficial
04-18-2015 01:11 AM
