xenon lights
Old Jan 9, 2009 | 03:18 PM
fraseman999's Avatar
Hi Folks,
My last bmw had the standard halogen bulbs and i got the kit to upgrade them to xenons. Fantastic result. My new wheels came with xenons factory fitted and they are total crap. When on dip and if its raining it borders on dangerous. Now i see that you can upgrade the d2s bulbs to 6000k or 8000k but my understanding is that although they may look cooler, they dont give out more light.
I dont want to look cool i just dont want to hit anything.
Does anyone have any advice?
Thanks
Old Jan 9, 2009 | 03:41 PM
m630's Avatar
if you have a 6er, or any BMW for that matter, that has bad lighting, then something is wrong and you should have your dealer look at the car...i drive on ocean side roads with no street lights without issue on the factory xenons, which is at ~4200K; 6K or higher are a more purple/blue color, the higher the temp the less actual light...
Old Jan 9, 2009 | 03:46 PM
Thanks for the reply, its a 530d i have. When you stand in front of the vehicle they look really bright but when driving they are very poor. On the diagnostics they are not showing any faults.
I am going to contact a company that sells upgrade bulbs and see what i should expect from them.
Cheers
Old Jan 9, 2009 | 04:26 PM
m630's Avatar
wow that is strange, my do perform flawlessly in trully dark situations...good luck with your fix!
Old Jan 9, 2009 | 04:35 PM
Richard in NC's Avatar
Mine are fantastic in all situations. If you drive past a wooded area, how well do you see the swath of light down the right side of the road? It should light up a 6-10ft tall 100 ft long area. Also, straight ahead, I see the reflectors on the road for 100s of feet.
Old Jan 9, 2009 | 05:30 PM
schulrog's Avatar
There virtually no light loss between 4500, 6000 and 8000K. where you might start noticing it is 10000K up. 6000K is pure white. 8000K is slight blue.
Old Jan 9, 2009 | 05:50 PM
m630's Avatar
not sure where you heard that, but 4200 is nearly optimal, 6K is way blue...
http://www.sizes.com/units/color_temperature.htm
Old Jan 9, 2009 | 06:01 PM
schulrog's Avatar
Where did I hear that from? nowhere just experience my friend I've been dealing with automotive lighting for quite some time now not to mention that I've had everything from 4500K(stock)-12000K so I have a pretty good idea
I can post 100's of pics of lighting temperatures that are all different haha here's an example. Anyway.. it also matters if you are talking halogen or xenon since the scales are going to be different.
Old Jan 9, 2009 | 06:08 PM
NWS Alpine's Avatar
Yes the ~4300K color temp has the best light output in lumens. If the OP wants better lighting he needs to retrofit his 35w ballasts with 55w ballasts. The D2S bulbs will burn out faster but they will still outlast halogens. If after a ballast upgrade you still aren't happy you could replace the lens of the projector itself with a euro spec lens. They are typically more optically clear. The US DOT requires the lens to be cloudy to reduce the lumens because they think they blind oncoming drivers.
Old Jan 9, 2009 | 06:10 PM
m630's Avatar
Originally Posted by schulrog' post='764129' date='Jan 9 2009, 10:01 PM
Where did I hear that from? nowhere just experience my friend I've been dealing with automotive lighting for quite some time now not to mention that I've had everything from 5000K-12000K so I have a pretty good idea
im talking temp, there is only one color scale for one temperature value, and as you can see even on your pix, pure white is 4K while 6K is blue, xenox nor halogen makes a difference
