tire blown, twice now...
Clearly looks as though there is something rubbing on the inner area of the sidewall while driving. I bet it it happening when you hit dips in the road and the suspension flexes down and a slight rub occurs. Over time it wears down, down, down........ then BOOM!
You might try 285's instead of 295's to avoid this.
Wheels are custom made, made for the car, no spacers needed. I'm pretty sure my suspension is saggin lil more than it's suppose to. Note to self, do not drive 2 hefty size girls in the back seat of the 6.. lol...
all i'm saying is that spacers would help if something is actually rubbing on the inside. (on top of making your cars stance more aggressive) something to consider if you are left with no other options. maybe you could even fit 305/25/20's with some spacers.
i run 40psi all around to protect my wheels, this is pretty much standard unless you plan on tracking the car or driving in snow.
those rims are awefully big and wide for that car.
you're running a narrow tire on that rim, and with the short sidewall, it makes it worse. i think going to a 285 is going to be worse.
you're streching the tires on those rims, and you definetly need to keep the air pressure very high on those tires, so that the sidewalls dont flex anymore and heat up and blow.
can you go 295/30?
can you go 295/30?
can you go 295/30?
can you go 295/30?
Falkens run a bit wider than the toyo's. Toyo are more comfortable and grip better though. I had all toyo's prior to switching to my falkens but for the price i won't complain for the bit of lost grip, (easier to powerslide anyway lol thats a plus sometimes)
good luck with this fitment seriously though spacers before you consider a minivan!!
I see where you're going with the spacers but my rims are flush with the fender. Spacers will definitely push my rim out pass the fender, and I don't think that look will look right on a 6. Maybe on a 89 honda accord, but lets see how these falkens work out. thanks for the advice!
yea I'd rather not see you in a minivan np !
