Lucky645ci and Sleek slam the 6 part 2.
Old Jan 11, 2009 | 12:47 PM
2modfast's Avatar
Originally Posted by schulrog' post='764840' date='Jan 11 2009, 01:05 AM
need spacers!
+2
Old Jan 11, 2009 | 01:22 PM
C's Bimmer's Avatar
Looks great. Now it just needs some tint!
Old Jan 11, 2009 | 03:08 PM
Sam@sleekmotoring's Avatar
Right now, in those pics, the car has not been aligned yet. The back has alot of negative camber. Once the camber gets adjusted, we can determine how thick of a spacer to go with.
Old Jan 11, 2009 | 05:03 PM
NWS Alpine's Avatar
Originally Posted by Sam@sleekmotoring' post='765371' date='Jan 11 2009, 07:08 PM
Sam I got my KW coilovers in today but something is very wrong. I get a clanking sound when I hit bumps at low low speed just testing it. I think I might need spacers in the front for the stock wheels. It seems like the rim might be rubbing the spring or perch. There is little to no room. I'm so pissed right now. I knew that I needed them for my 22s but not for my stock rims. Now I have to wait but I haven't heard anything from ModBargains.com about my order for the 10mm spacers. I can't drive my car now.
Old Jan 11, 2009 | 07:59 PM
If the tire is hitting the spring pearch, try to raise up the perch until it does not hit the tire/wheel anymore. If there is no way of making the perch clear the wheel or tire, you need spacers. Also, see if there is any tire contact marks on the actual coil spring. Depending on the shape of the coil spring, you may be able to turn the coil to give the tire some more clearance.
If its making a large clanking sound, check to see that you tightened the bolt on top of the struts all the way. If the KW's use your original upper spring perches, make sure the end of the spring is sitting on the perches properly.
Old Jan 11, 2009 | 11:37 PM
Stratus650's Avatar
My Ride: '07 650i
btw Sam, from my experience with the coilovers, I can hear minor bumpy sounds when the coilovers are cold and I didnt drive the car for the while, specially when just out of the garage. usually it disappears after the shocks warm up.
Old Jan 12, 2009 | 11:06 AM
tbal's Avatar
My Ride: See sig :)
Oooo that would annoy the crap out of me... You pay so much for coilovers and they sound like that!... no thanks, my other car on airbags, sounds like that, its DAMN annoying lol
Old Jan 12, 2009 | 02:18 PM
Ive never ran into that problem before. I would think, just to make sure the spring is seated properly and that all the proper rubber pads and bushings are in the proper places. Sorry I couldnt really help you on this one.
Old Jan 14, 2009 | 10:56 PM
Stratus650's Avatar
My Ride: '07 650i
Originally Posted by Sam@sleekmotoring' post='766116' date='Jan 13 2009, 03:18 AM
Coilovers were checked more than twice, it's just the way they are designed, coz mine are progressive springs (2 different springs on top of each other) to improve comfort while maintaining stiffness when necessary... have a l@@k...
Old Jan 15, 2009 | 05:48 AM
NWS Alpine's Avatar
Those look exactly like my KW setup just the only difference is mine are purple where yours are blue. I wonder if KW makes them for hamann. Those smaller springs are what they call helper springs. They are fully compressed when on the car. They don't change the spring rates much if any. They really are only there for when you have the car slammed realy low they keep the main spring seated in the top perch. Some people remove them if they aren't dropping the suspension really low so they can move the perch up higher and get more clearance for wider tires.
Those spring only hold about 80-100lbs load and you can compress them by hand.
