2005 BMW 645Ci dead?
My Ride: 2005 BMW 645Ci
Hi, I am new to this forum. I am looking for some help from anyone who have been to this before and all those who have great ideas. I have acquired a 2005 BMW645Ci with only 50K original miles(lucky right), last Dec,2019. I did not use the car as I want to changed valve cover gasket first. So Jan,4,2020 I disconnected the battery and proceeded on changed the valve cover gasket as as oil was leaking/dripping on exhaust manifold. After VCG changed Jan,5, plugged the battery back in and started the car-rough idle, and gas pedal seems not responding until checked engine light came on. I turned the ignition off, checked code, P0120(throttle/pedal position sensor/switch A circuit), P0123(throttle/pedal position sensor/switch A circuit high), P0222(throttle/pedal position sensor/switch B circuit low) and misfire on cylinder 1,2,5 and 7. So I checked my throttle body and noticed the harness was not all the way in. When I tried to turn the engine on again, I have no crank, only flapping noise what sounds to be from throttle body butterfly and my dash board light up(blinking) like a Christmas tree. I disconnected the battery again overnight and tried the next day(Jan,6), still no crank, dashboard still light up like Christmas tree, only the back window works. I tried t again this afternoon, still no crank, this time all my light were out, no power whatsoever. I checked the battery, its reading only 11.4V.
I checked all fuses, all are good(passenger footwell). I don't know how to checked DME, CAS and power module if it is working right.
So any input/ideas will be greatly appreciated !
Thanks in advance.
Thanks in advance.
Engine: 3.0 B58; 3.0 M54
You're at 11.4v. The battery needs to be recharged. It needs to be at least 12.1v to start the car with no issues preferably 12.3v
Thanks for your reply! I am going to bring the battery to advance auto parts to have recharged, hopefully that’s the only issues. I’ll let you know when I have it back and tried to start the car again. I really appreciate you! Just a thought, have anybody try jump the car? I don’t know if it’s safe for this car?
5soko
Oct 30, 2013 05:44 PM
