Bagged F30 M3 Pushes Low to the Extreme
By -
F30 Bagged Bags
F30 M3 drops it all the way to the ground.
Love it or hate it, airbag suspension has a huge following. Those in the stance crowd love it because it gives them exactly the look they desire at a show, and lifts up for other uses. Sometimes it can be tuned for, and used, in performance applications, but this isn’t the case for this F30 located in Great Britain which we stumbled across on Instagram.
Registrations typically stick with a car in the United Kingdom, so this one is affectionately known as N444 RVS. As is usual with a car on bags, wheel choice is always changing. In a number of older pictures this car is on M4 GTS style wheels. The tight fit on those is truly incredible, nearly touching the fender at times. As a look to aim for, mission accomplished. But currently, sits on Porsche’s Artec Turbo P wheels, which allow the car to sit even lower as seen below. Like, front-lip-touching-the-ground kind of low.
It’s a Robbery 💎 [ 📸 @psinghworks ] • • • • • #royalair #wokeuplit #royalworksuk #lifeonair #airliftperformance #caraudiosecurity #violentclique #f30 #mperformance #blacklist #superstreet #bmwfanatics #slammeduk #bavarian #ig_bmw #ultimatedrivingmachine #murderedout #murdered #bmwgram#bmwgasm #bmwgods #bimmersociety #bimmerpost #bimmerlife #baggedbmws#stance #bmwclub #hellaflush #airride #violentclique
A post shared by â–ª N444 RVS â–ª (@bagged__f30) on
Don’t be let down if it was more bagged F30’s you are looking for on this IG channel. Even though it’s only one. This owner changes things up frequently. And let’s be honest, with the modified headlights, blacked out trim, carbon fiber accents and stance, this F30 shows what bags can really do for a car. And it is also apparent that this owner has installed some excellent custom audio as well.
Fuck a suit and tie, I got drip on me 💎 [ 📸 @psinghworks ] • • • • • #royalair #wokeuplit #royalworksuk #lifeonair #airliftperformance #caraudiosecurity #violentclique #f30 #mperformance #blacklist #superstreet #bmwfanatics #slammeduk #bavarian #ig_bmw #ultimatedrivingmachine #murderedout #murdered #bmwgram#bmwgasm #bmwgods #bimmersociety #bimmerpost #bimmerlife #baggedbmws#stance #bmwclub #hellaflush #airride #violentclique
We know some folks may say that a good coilover kit will offer so much more than what bags could ever do. But this owner wants the car to be an expression. And between the stance, wheels and custom audio, there’s no denying this is one ride which has had its fair share of time and effort put into it, with maximum enjoyment as a result.
Join the 5Series forums now!
