Blauparts: Year End Liquidation of Formal Approval BMW LL-01 Motor Oils! $5.71 Liter
Formal Approvals: BMW Longlife-01 Motor Oils, HCL 5w30 $5.71!
Up To 40% Off! Plus an extra 10% off with coupon code Final13
Guaranteed To Be The LOWEST PRICES on the web or anywhere!
These deals are Limited To Stock On Hand! - Offer Ends 01/01/2014
Ravenol HCL SAE 5W-30
Ravenol HCL is high performance low friction BMW oil with CleanSyntoฎ fully syntheic technology. It can be used with gas or diesel engines with and without turbo-charging and direct injection. The formulation of Ravenol HCL CleanSyntoฎ BMW motor oil reduces the engine's internal dynamic drag and can result in an 8% increase in fuel mileage, cleaner engine components, reduced engine emissions, maximum engine durability, reduced maintenance costs, wear and has excellent cold start characteristics. It is also suitable for extended oil change intervals where recommended by manufacturer.
Factory Approval: BMW Longlife-01
Ravenol HCL SAE 5W-30 has received formal approvals from BMW in accordance with the BMW Longlife-01 oil spec. It also carries formal factory approved from Audi Vw for VW 502 00, 505 00 oil specs and from Mercedes for Mercedes Benz 229.5 oil specs. Read more about formal oil approvals here.
Ravenol HCL Features:
Made In Germany
Improved fuel economy
Excellent shear stability
Excellent cold starting characteristics
Secure lubricating film in high operating temperatures
Excellent detergents and dispersant property
High wear protection
Prevention of foam formation
Extended lifetime because of oxidation stability
Excellent Viscosity behavior
ACEA A3/B4
OE Reference: BMW 07 51 0 017 866
Approved BMW Longlife-01 Oil Spec Used in:
All 2001 and present BMW gasoline engines. (Not to be used in M Series Model Or Applications)
BMW Oil - 5W-30 Weight - Motor Oil Spec BMW Longlife-01 - German Ravenol HCL - 1 Liter
BMW Oil - 5W-30 Weight - Motor Oil Spec BMW Longlife-01 - German Ravenol HCL - 5 Liter
BMW Oil - 5W-30 Weight - Motor Oil Spec BMW Longlife-01 - German Ravenol HCL - 5 Liter - Case of Qty 4
Formal Approvals: BMW Longlife-04 Motor Oils, VMP 5w30 $8.14!
Ravenol VMP SAE 5W-30
Ravenol VMP 5W-30 is a high performance fully synthetic BMW motor oil designed to meet the latest requirements of modern European manufacturers. VMP contains a modern blended additive formulation to give engines outstanding protection for extended drain intervals at high temperatures and in extreme pressure situations typical for modern gasoline and diesel engines.
Factory Approval: BMW Longlife-04 gasoline and diesel motor oil specification requiring extended drain intervals.
Ravenol VMP SAE 5W-30 has received formal approvals from BMW for BMW Longlife-04 oil spec and from Audi Volkswagen in accordance with the latest VW 504 00 (European) and 507 00 specs. It also meets Mercedes Benz MB 229.31 and 229.51 along with Porsche C30 oil specifications. Read more about formal BMW oil approval here.
Ravenol VMP Features:
Designed for Euro IV and Euro V vehicles requiring low SAPS technology. (low Sulphated Ash, low Phosphorus and low Sulfur rates.)
Reduced vehicle polluting emissions.
Ensures DPF (Diesel Particulate Filter) and TCW (Three Way Catalyst) longevity.
Designed for extended drain intervals.
Specially formulated to improve fuel economy.
Quick cold weather starting and good lubrication at temperatures as low as -30ฐC. (-22ฐF)
Reduced oil consumption thanks to the use of high end synthetic base oils.
Outstanding prevention of engine carbon, lacquer, and sludge deposit build up.
High thermal stability and oil oxidation resistance in maintaining internal engine cleanliness.
Excellent engine lubrication, oil film stability, and anti-wear protection in the most demanding engine performance conditions.
ACEA A3/B4 C3
API SM
OEM 07 51 0 037 195
Approved BMW Longlife-04 Oil Spec Used in:
BMW 335d E90 Chassis 2009-11
BMW X5 E70 Chassis 2009-13
BMW Oil - 5W-30 Weight - Motor Oil Spec BMW Longlife-04 - German Ravenol VMP - 1 Liter
BMW Oil - 5W-30 Weight - Motor Oil Spec BMW Longlife-04 - German Ravenol VMP - 5 Liter
BMW Oil - 5W-30 Weight - Motor Oil Spec BMW Longlife-04 - German Ravenol VMP - 5 Liter - Case of Qty 4
Why Choose Ravenol German Motor Oils?
Lowest prices around for the highest quality oils (compared to other brands).
Comprehensive line up of FACTORY APPROVED motor oils. Superior quality confirmed and acknowledged by leading German automotive manufactures; with Formal Factory Approvals from Volkswagen, Audi, Mercedes Benz, BMW, Porsche, and many more. Ravenol's focus has always been to engineer high end specialty synthetics that offer the ultimate performance for each specific engine requirements. They offer many of the latest oil specifications and some of the best TDI oil we've ever stocked.
100% genuine German. Manufactured and bottled in Germany since 1946! Ravenol mixes and bottles their own proprietary blend and brand of lubricants to the highest European O.E. quality standards.
Note: In the US most oils that are offered in large retail superstores are not actually manufactured by the brand name shown on the bottle. These massive oil corporations are not making their own oil. With a focus on price above quality, many big oil brands outsource and have a generic refinery bottle the oil for them. This isn't the case with Ravenol fluids! Ravenol is unique in that they have TOTAL CONTROL over the QUALITY during their manufacturing process. Their lubricants are manufactured within their own refinery and factory in Germany to the highest European O.E. quality standards and have been awarded many O.E. APPROVALS for superior quality.
Read some of the results that are returned when searching "counterfeit motor oil" on Google. You'll be surprised by the rising amount of counterfeit oils on the market. You won't have to worry about these problems due to Ravenol's revolutionary anti tamper technology. Ensure engine reliability with genuine Ravenol motor oil.
Ravenol has steadily become established in virtually all forms of European Motorsport and is today the Technical Partner to an ever increasing number of established Race and Rally Teams and Series. Ravenol is currently actively committed to supporting teams in WTCC, Formula 3, Sports and Saloon Car Racing, Rallying, Truck Racing, Motocross and even Power Boat Racing.
Plus Save an EXTRA 10% Off on SELECT Current Sale Items with Coupon Code FINAL13!
$15 Off Select BMW ATF Cases & 10% Off Select 1L Bottles
10% Off All Ravenol of Germany Fluids
$30 Off All BMW Strut and Shock Replacement KITS & an Additional 10% Off with coupon code FINAL13
$15 Off All BMW Strut and Shock SETS & an Additional 10% Off with coupon code FINAL13
Overstock Sale on Select BMW Motor Oils
Website:
www.blauparts.com
* Free shipping offers are for FedEx Ground shipping to 48 US contiguous states only. Offers End 1/01/2014
TroyE60
05-30-2019 05:01 PM
