F10, F11 Parts, Accessories and Mods Discussion about both stock and aftermarket parts for the F10. Accessories and modifications too!
2014 F10 standard stereo system to Gladen/Mosconi
Old 08-09-2015, 10:50 AM
Germaniks's Avatar
My Ride: e39
Default 2014 F10 standard stereo system to Gladen/Mosconi
Standard F10. Stereo option (No tweeters, no amplifier from factory)
The kits
Speakers : Gladen 201 kit - Gladen MC 100 for the rear shelf.
Amplifiers : Mosconi 120.4 DSP (4 channels, class AB, Digital Sound Processing built-in) and a Gladen RC 90 C 2 channels to power up the under seat woofers.
Replacing the mid range speakers in the front door cards.
Trims from the trunk removed.
Front seats removed in order to install new woofers.
New fuse block 1 way in, 2 ways out to keep things tidy.
Replacing rear speakers with Gladen MC 100
Running the new 4 channels radio loom all the way to the trunk to get the audio signal from the radio unit.
Wires, wires...and a custom cut wood panel to secure the amplifiers.
Testing fitment, all good
Installing the new fuse block securely. Almost can't tell it is not factory original.
Small 2 channels Gladen RC 90.
Amps fully installed and secured with forced cooling.
USB plug for adjusting the Mosconi DSP settings if needs be without having to remove anything.
carid
07-18-2015 01:18 PM
funglenn
07-11-2015 03:45 AM
pantzjantz
07-07-2015 04:44 PM
shervinj
07-02-2015 07:29 PM
lukieno1
07-01-2015 04:37 PM
Quick Reply: 2014 F10 standard stereo system to Gladen/Mosconi
