Active Backrest Retrofit
#21
Hello mate, can you please guide me where I am fitting a new seat from M5 which has active backrest and heating from factory. Mine was basic half electric seat.
Normally I ran a cable from SGM (K_CAN_SH/SL) to the seat X275/279 (yellow connector). There is an additional ground which I connected to the driver side 8 pin connector pin 2. Now when I try to use the buttons on my seat passenger side seat button activates driver side seat and vice versa.
Also what all cables are required is to be taken from KGM for backrest width adjustment to work? Aren't they on K_CAN? Any additional power to be fed? Can you please point me to the right direction?
#22
Don't know how to edit the post above. This is how I have wired it:
Ran two cable for K_CAN from SGM to the 8 pin connector. Ran a cable for LIN bus (K_BUS) from yellow connector to the SGM, actually I reused the existing wiring which was there for the seat heating.
#23
Engine: N54
I'll write some more when I get a moment and not on my phone....
Both active backrest modules are the same. What determines whether it is a driver side or passenger side module is if an Extra pin is grounded or not.
#24
Thanks, got the buttons sorted, grounded one is passenger I thought it was driver side hence the problem. Now switches are all sorted.
Regarding the active backrest width feature I will need to take 3 wires from the KGM (PT CAN HI/LO and WAKEUP) to the seat module. I don't know which pins of yellow plug they will go to, can you please help me there. Also what is function of WAKEUP line?
#25
Engine: N54
#26
Congrats!!
Just so your know ALBV_TOGGLE_APP is the function in CAPPL.
If you enable MDRIVE and MDRIVE_ALBV in CAPPL this should give you the seat adjustment menu.
#27
Engine: N54
after having lived with this now for a while I can say I really like the Active Backrest. The seats react very quickly to changing conditions and provide a lot of support in the turns that you wouldn't otherwise have. For example, it may not be practical to have the side bolsters closed as small as they will go because it may be too tight for a lot of guys. With this setup, the seats are left open to a comfortable but supportive position and when a turn is taken the outside side bolster closes in fast and in stages to get progressively tighter the more aggresive the turn.
#28
Ok, got it connected now.
Active backrest width adjustment will need PT CAN line as it gets its data directly from DSC which tighten the side bloster on turn. PT CAN line can be taken from KGM.
On X275 PIN 20 is WAKEUP line connect this to PIN 27 of KGM X16760
X16760 on KGM (first big connector from left) PIN 30 is PT_CAN_L and PIN 29 is PT_CAN_H and on X275/X279 PIN 16 PT_CAN_L and PIN 15 PT_CAN_H. Connected them togather.
Code SA4MA, SA456, SA4MF (only with active backrest width adjustment), all functional. Now I need to replace the switches and all done.
Side blosters are making cracking noise when tightening or opening, as if something is being tightened too much but it is very responsive. Haven't connected the passenger seat yet so don't know if both do it or it is just the driver side. Is this what you guys experiencing too? Is it normal or the active backrests are on their way out.
kd7iwp (08-23-2020)
#29
Engine: N54
