Headlight Wiring Outer Jacket Deteriorating
#51
My Ride: '06 530i
Hi all,
I had assumed that the headlight wiring issue was isolated to the E60's but a post on another forum has revealed a 2004 330Ci to be affected as well.
I guess I should start to list known vehicles of people that have a wiring problem.
Not that it would mean if you do not own one of the cars listed you are safe, I would still urge ALL BMW Car owners to keep a close look inside their headlights.
However if you DO own one of the cars listed below you really need to be very aware of this problem and keep an eye on your headlight.
It is a Cancer in your headlight and the earlier that you catch it, the easier it is to repair.
Starting with my car first:
1) 2006 530i (with Adaptive Headlights. Part # 63-12-7-160-157)
2) 2004 525i
3) 2004 530i
4) 2004 545i
5) 2004 330Ci
6) 2007 530i
7) 2007 335i
8) 2008 528i
9) 2008 535i
10) 2008 550i
If you have this problem and do not see your car listed please tell us here and I will update the list....
Bud
2) 2004 525i
3) 2004 530i
4) 2004 545i
5) 2004 330Ci
6) 2007 530i
7) 2007 335i
8) 2008 528i
9) 2008 535i
10) 2008 550i
Bud
#52
update on mine. I stopped by and talked with the shop Forman at my local dealer. they are going to take the car in Monday and try to justify a warranty claim before I go down the BMWNA path of getting a exception.
#53
Oh, I think you are very lucky! If they end up changing out the headlights ask them if they are going to diecard them there or actually send them to NA. I would be interested in purchasing them in their current condition! Its really a hit and miss, because sometimes the throw them inthe trash and others get returned.
#54
My Ride: '06 530i
Hi all,
As my post suggests I have had to rewire my complete headlight because my wires had degraded to bare copper.
What little insulation that remained on the wires crumbled and flaked off when I touched them.
Because it has been so invasive I wonder if it will work but I had to try!
I've added some pictures and I will post back with the results..I think that I'm almost done.
I had to get some liquid tape to seal around the heat shrink in a few places.
A few pictures..... In the last picture you can see the Fiber Optic Covered in Heat shrink.
Also in the harness you can see one last bare copper wire that I need to cut out and then solder in a new color-coded wire....
Yes welcome to my Nightmare!!!
Bud
Do you like my insulation speckled work table? LOL!
Bud
#55
For areas of the car that aren't protected by the elements "dual-wall adhesive heat shrink tubing" is a better choice that regular heat shrink tubing.
#56
Hi all,
Bud
Bud
#57
My Ride: '06 530i
Hi all,
I replaced every wire with new color coded GXL wire @ 20ga. cut at each end and soldered in line.
GXL Wire is good to almost 300 degrees Fahrenheit and is impervious to oil, gas, just about anything that would be under the hood of a car.
GXL wiring is also standard for Ford, Chrysler and GM..Obviously not BMW! +
I was going to go with adhesive heat shrink but decided against it because the headlight is relatively a sealed unit.
The heat shrink just barely slid over the wire so at 2-1 shrinkage it shrunk down very very tightly around the wire and solder joint.
I lastly used black liquid tape at every connector to seal the ends of the wire / heat shrink and where the original wires connects into it's plug / connector.
Well I am finally ready for my "Power On" test after completely rewiring my headlight.
AMAZING..It actually works!
Now I just have to finish putting it all back together.
Bud
Bud
#58
my update. not much to report. my Dealer still has a case open with BMWNA. its been 10 days and no news back. I hope that it is a good sign because I didn't get the immediate "no" answer
#59
My Ride: 2008 535i
Engine: N54
Guys,
I know that this is an old issue but I have a 2008 and have the same issue and BMW treated me the same way they did to others. I filed a complaint with
Keeping You Safe | Safercar | National Highway Traffic Safety Administration (NHTSA).
Please file complaints even if your issue is old. Thats the only way to make BMW liable and honest. The more complaints the more pressure.
umnitza
11-03-2015 02:58 PM
525i_owner
19
10-12-2015 11:00 AM
ucsbwsr
12
07-27-2015 11:20 AM
