E39 Discussion Anything and everything to do with the E39 (1997 - 2003) 5 series!
Help with INPA coding
Old 12-30-2015, 10:20 AM
AmericanJambo's Avatar
My Ride: e39 525i
Default Help with INPA coding
Hey guys, they're a couple things I'm looking to do with INPA. I've searched but I haven't found what I'm looking for.
What I want to do is code off the high beams as running lights and use the halos on full brightness for my running lights.
Second, I need to code in the ABS pump which was replaced right before I bought the car and recalibrate the steering angle sensor. The DSC light is on and won't turn off. It's not throwing any codes and I've been told that coding in the ABS pump and or recalibrating the steering angle sensor will fix this issue.
I've never used INPA before. I've got a copy of it that I haven't installed yet. Waiting on my cable to arrive. Will it work on Windows 10?
Thanks for the help guys!!! I really appreciate it.
Old 09-16-2016, 01:32 PM
oleg71's Avatar
My Ride: BMW 530i Engine M54
To encode the blocks you need a program NCSExpert or program NCS Dummy.Also needs to be installed ediabas 7.3.0.
mrbrooklynkat
08-09-2023 05:02 PM
rodybmw
04-23-2021 08:03 AM
Padilla74
07-19-2015 03:08 PM
CVTBenhogan
07-13-2015 06:46 AM
brente91
07-12-2015 10:19 AM
Quick Reply: Help with INPA coding
