Help with INPA coding
Hey guys, they're a couple things I'm looking to do with INPA. I've searched but I haven't found what I'm looking for.
What I want to do is code off the high beams as running lights and use the halos on full brightness for my running lights. Second, I need to code in the ABS pump which was replaced right before I bought the car and recalibrate the steering angle sensor. The DSC light is on and won't turn off. It's not throwing any codes and I've been told that coding in the ABS pump and or recalibrating the steering angle sensor will fix this issue. I've never used INPA before. I've got a copy of it that I haven't installed yet. Waiting on my cable to arrive. Will it work on Windows 10? Thanks for the help guys!!! I really appreciate it. |
To encode the blocks you need a program NCSExpert or program NCS Dummy.Also needs to be installed ediabas 7.3.0.
