E39 Discussion Anything and everything to do with the E39 (1997 - 2003) 5 series!
2000 BMW 528i wonky headlight and turn signals
Old 08-25-2015, 10:44 PM
hmilycar's Avatar
My Ride: BMW
Default 2000 BMW 528i wonky headlight and turn signals
Good day to all. New here. I have issue with headlights. Lights were working fine, however recently only hid and high beams were working on passenger side. So i figured bulb(s) were burnt on on driver side. Pulled all the bulbs and tested them on working side not just visually inspect. re-installed bulbs and boom everything started working again. So i figure corrosion and something jarred everything loose and back on my Launch X431 ICarScan . However next start up same problem no driver side lights. I unplugged high beam bulb and lights came back on? put high beam back in and same problem. Now this is where it gets really weird, When I am driving if i turn on right turn signal and hit brake, turn signal stops working until I let off pedal. If I turn left and hit brake pedalcar signals to right if I left off brake pedal. I tried battery reset (30 minutes disconnect) Didn't work. Do you think its the LCM or is my car haunted... btw checked all fuses and the usual. If so does anyone know anyone stateside that sells them programmed or do i need to get programmed at dealer. Thanks everyone. I would list my cars I have owned but way to many 42 to be exact.
Launch CRP129 is created through the entire desire for a solid ultra-fast regimen number scanning and management software including full sub-system a good defense, simultaneously with perfect PID answers capturing or maybe graphing understanding, within a asking price which generally Launch CRP129 might be a small group about the proficient confirm software.
socale39
09-05-2023 08:30 AM
Kasmo
05-07-2019 03:30 AM
kumarnbk
03-30-2015 02:12 PM
tom333
03-20-2015 12:30 PM
08-12-2003 11:41 AM
Quick Reply: 2000 BMW 528i wonky headlight and turn signals
