Sunroof won't initialize
FYI - I think the original sunroof problem could've been solved without coding. I had the same issue with it closing in increments then sticking open all the way after coding my AUX module but found out that if you just push straight in & hold the sunroof button for a minute or so it will cycle through the whole incremental process to close it then reset itself to factory.
