.:Trinity Autosport:. AP Racing 6-Piston Big Brake Kit E39
Hi Guys,
We are happy to offer all you E39 guys the AP racing big brake kit.
Original Equipment (OE) brake systems do the job they were intended to, stop safely and quietly for the lowest cost possible. After adding performance upgrades, while towing, or just having some fun in the canyons, OE brakes are often overwhelmed by heat when the moment of truth arrives.
Big Brake Kits give your vehicle that super car look and feel, while significantly improving your brake performance in two areas. First, larger brake discs increase heat capacity, meaning your brakes will be more resistant to brake fade. Second, stiffer calipers and brake lines increase pedal feel and modulation.
For the biggest brake system upgrade, AP Racing offers 6-piston calipers running on 2-piece rotors. Each kit is designed to work with the original equipment master cylinder, ABS and traction control systems. Specially-designed 2-piece rotors are cross-drilled and slotted, the optimum for high-performance street, autocross and occasional track day use. Slotted-only versions are available for the serious track enthusiast. The curved vane construction provides maximum cooling, while significantly reducing unsprung weight.
DOT-compliant and TÜV-approved stainless steel lines are included to top off the upgrade and provide a huge improvement in pedal feel and stiffness. Brackets and hardware are made from aerospace-grade materials and high-strength fasteners. All AP Racing kits are complete with no other parts required. Install, bleed and go!
Retail is $3,695 but we are running a special! PM us for special pricing
Thanks Guys
Thanks Guys
DetailersDomain
Detailing Forum
Oct 13, 2015 06:05 PM
PelicanParts.com
Aug 14, 2015 10:15 AM
