Powerflex Polyurethane Suspension Bushings - Qualify For Free Shipping!
Old Aug 4, 2015 | 01:34 PM
PelicanParts.com's Avatar
Vendor
My Ride: BMW 700 and More!
Default Powerflex Polyurethane Suspension Bushings - Qualify For Free Shipping!
5 Series! Worn suspension components? Upgrade with a more cost-effective bushing!
Pelican is pleased to now offer Powerflex polyurethane suspension bushings. These bushings are a great alternative to factory rubber bushings which are more prone to wear, resulting in poor tracking and handling. What are the benefits to using polyurethane over rubber? Prolonged tire life, improved performance, better handling and they are more cost-effective than OEM bushings. Suspension bushings are some of the most highly stressed components fitted to a motor car. They undergo enormous strains in the most arduous of conditions with no maintenance or lubrication. The material they are manufactured from is a rubber compound containing natural products which deteriorate with age. It becomes softer and more pliable, resisting the forces placed on it less and less. Therefore allowing more and more movement of suspension components and offering less and less control over the suspension geometry. This in turn causes accelerated tire wear, braking instability and poor handling. This is the single biggest reason you can instantly tell the difference driving a three year old car compared to a showroom new one. However even new cars will benefit from Powerflex bushings because of their superior design for which they offer much more effective control of the suspension components to a much greater extent than normal rubber items. With the technological advances in this material, it has been possible to overcome the common problem associated with harder bushings, which is increased noise. By correctly engineering the polyurethane compound, bushings can be made 25-30% stiffer than new rubber items, but with exactly the same noise absorbing properties. Powerflex bushings make sense.
All Powerflex bushings include a packet of grease.
Purchase $149 or more and qualify for FREE Shipping!
Fitment
- 540i (1997-03)
- M5 (2000-03)
- 525i and 530i (2001-03)
- 528i (1997-00)
And more! Search your application 5 Series here.
Suspension & Steering > Suspension Upgrades & Performance > Powerflex
der99649
Oct 21, 2015 03:51 AM
ArnottInc
May 11, 2015 11:56 AM
ArnottInc
Apr 2, 2015 10:46 AM
DetailersDomain
Detailing Forum
Mar 24, 2015 05:25 AM
