FS: License Plate Replacement LEDs Super Bright White
Banned
My Ride: A Car
These are only replacement LEDs not the RDash replacement housings. Super bright white. $38 shipped. Pictures will be up within 2 hours. No error messages and no premature blow out. Tested over 2 months on BMWs.
Banned
My Ride: A Car
Originally Posted by PraiseTheLowered' post='1085224' date='Jan 6 2010, 10:47 AM
is the swap pretty easy? and do you give military discount?
DIY (This DIY shows you how to remove the license plate lamp housing. Follow it to remove and then swap out the bulb): https://5series.net/forums/index.php?showtopic=83742
ALL OTHER DIYs: https://5series.net/forums/index.php?showto...p;#entry1004130
PM Sent!
Banned
My Ride: A Car
Originally Posted by 08white' post='1085376' date='Jan 6 2010, 03:06 PM
what is the differece between these and the ultimate LED?
The "ultimate" are the license plate lamps. They replace the entire housing and has 18 regular sized SMD LEDs there. These 3 HUGE SMD LEDs has 3 chips per SMD which equates to 9 SMD LEDs. The license plate lamps are double the brightness.
Banned
My Ride: A Car
Do not confuse these with the License Plate Lamps!
These are License Plate LEDs. The License Plate LEDs are a direct replacement of the bulb and is double the brightness of stock bulbs. $38 shipped.
License Plate LAMPS replaces the ENTIRE housing and is DOUBLE the brightness of the LEDs! AT LEAST 4 times brighter than stock. $60 shipped
