BMW X5/X6 F15/F16/F85/F86/E70 brake caliper adapters to install F10 M5 brakes
Old Sep 13, 2018 | 12:36 AM
tro-nik's Avatar
My Ride: 5Series
Model Year: 2018
Default BMW X5/X6 F15/F16/F85/F86/E70 brake caliper adapters to install F10 M5 brakes
We are engaged in the design and development of complex engineering solutions. We manufacture these solutions to these decisions.
We sell adapters for mounting the brake caliper from BMW M5 F10 on your BMW X5/X6 F15/F16/F85/F86/E70/E71.
These front adapters allow you to install the 6-piston Brembo front brake calipers from M5 F10(34 11 7 845 747, 34 11 7 845 748, 34117845747, 34117845748)
or from F85/F86 (34 11 7 852 967, 34 11 7 852 968, 34117852967, 34117852968)
and the brake rotor 400 * 36 from M5 F10 (34 11 2 284 101, 34 11 2 284 102, 34112284101, 34112284102) to the front axle.
Adapters are made of duralumin D16T with anodized oxide coating.
Adapters are supplied with high-strength bolts fastening.
On photo you can see how the adapter is attached to caliper and to car
You only need to buy:
- left rotor - 34 11 2 284 101
- right rotor - 34 11 2 284 102
- left caliper - 34 11 7 845 747 (34 11 7 852 967 from f85/f86)
- right caliper - 34 11 7 845 748 (34 11 7 852 968 from f85/f86)
- pads - 34 11 2 284 869 (34 11 2 284 970 if you want even better braking)
- brake lines - 34 30 7 852 972
- sensor from your car
- two bolts - 34 11 1 123 072
You also can find additional info here - Adapters to install 400-36 rotors on BMW F15/F16/F85/F86
and our work - Brake system set installation BMW X5 F15 in blue
c7013498
F10 Discussion
Jan 21, 2018 12:00 AM
clnm5
Sep 7, 2014 03:25 PM
pinguhk
Apr 13, 2011 05:45 PM
FantomInfinity
Nov 12, 2009 01:47 PM
Knubblo
Bluetooth & Cell Phone Forum
Oct 7, 2008 09:03 AM
