BMW M5/M6 E60/E63 brake caliper adapters to install F10 M5 front calipers
We sell adapters for mounting the brake caliper and rotor 400*36 of the BMW M5 F10 on your BMW M5/M6 E60/E63/E64. These front adapters allow you to set the 6-piston Brembo brake caliper and the brake disk 400 * 36 cars to the front axle.
Adapters are made of duralumin D16T with anodized oxide coating.
Adapters are supplied with high-strength bolts fastening.
Attention!!!!!! You should to increase the central hole of the brake disc 400*36 on the lathe from 75 to 79 mm. because E60 and F10 have a different size of central hole
G-size on fotos!!!!!
