BMW G30/G11/G12, G32, G11/G12 all brake adapters to install M5 F90 all brakes
We sell adapters for install the brake calipers and rotors from BMW M5 F90 on any BMW
- 5er G30/G31/G38
- 6er G32
- 7er G11/G12
These front adapters allow you to install the:
- 6-piston Brembo brake calipers from M5 F90: BLUE (34 11 8 089 937, 34 11 8 089 938) or GOLD(34 11 8 089 939, 34 11 8 089 940)
- brake disks 395 * 36 (34 11 7 991 101, 34 11 7 991 102)
- front pads 34 11 7 991 033
and for rea
- rear rotors 34 21 7 991 103, 34 21 7 991 104
- rear calipers: BLUE( 34 20 6 882 997, 34 20 6 882 998) or GOLD (34 20 8 064 491, 34 20 8 064 492)
- rear brackets 34 20 6 882 989, 34 20 6 882 990 or GOLD (34 20 8 064 493, 34 20 8 064 494)
- rear pads 34 21 7 991 043
on your BMW G-series.
The blue and gold FRONT calipers are DIFFER. You should write to us, what front calipers you will use
The blue and gold REAR calipers are the SAME, differ by the color only
Front Adapters are made of duralumin D16T with anodized oxide coating.
Rear adapters are made of steal
Our kit is:
- two front adapters of duralumin D16T with anodized oxide coating
- 4 front high-strength bolts to install
- two rear steal adapters with anodized oxide coating.
- 4 rear high-strength bolts fastening
This front and rear adapters allow you to install the BMW M5 F90 FRONT and REAR calipers and the brake rotors on your front and rear axle of your G30/G31/G32/G11/G12.
Rear adapters in this set works only with M5 F90 rear calipers!!!!
In the place of attachment of the rear adapters on a hub it will be necessary to modify the hub - remove 2-3 mm.
Also we have another adapters.
If you have any question - just write us
The total price for adapters - 605 USD
