Blauparts: 10% Off Factory Approved BMW Motor Oil Longlife-04 (LL-04) Spec
![](http://www.blauparts.com/eimages/forum_images/9_13/blauparts_bmw_vmp_oil.jpg)
10% OFF Select German Ravenol BMW Motor Oils + Free Shipping Use Coupon Code NOV1113
Offers End 11/30/2013
Ravenol VMP SAE 5W-30
Ravenol VMP 5W-30 is a high performance fully synthetic BMW motor oil designed to meet the latest requirements of modern European manufacturers. VMP contains a modern blended additive formulation to give engines outstanding protection for extended drain intervals at high temperatures and in extreme pressure situations typical for modern gasoline and diesel engines.
Factory Approval: BMW Longlife-04 gasoline and diesel motor oil specification requiring extended drain intervals.
Ravenol VMP SAE 5W-30 has received formal approvals from BMW for BMW Longlife-04 oil spec and from Audi Volkswagen in accordance with the latest VW 504 00 (European) and 507 00 specs. It also meets Mercedes Benz MB 229.31 and 229.51 along with Porsche C30 oil specifications. Read more about formal BMW oil approval here.
Ravenol VMP Features:
Designed for Euro IV and Euro V vehicles requiring low SAPS technology. (low Sulphated Ash, low Phosphorus and low Sulfur rates.)
Reduced vehicle polluting emissions.
Ensures DPF (Diesel Particulate Filter) and TCW (Three Way Catalyst) longevity.
Designed for extended drain intervals.
Specially formulated to improve fuel economy.
Quick cold weather starting and good lubrication at temperatures as low as -30°C. (-22°F)
Reduced oil consumption thanks to the use of high end synthetic base oils.
Outstanding prevention of engine carbon, lacquer, and sludge deposit build up.
High thermal stability and oil oxidation resistance in maintaining internal engine cleanliness.
Excellent engine lubrication, oil film stability, and anti-wear protection in the most demanding engine performance conditions.
ACEA A3/B4 C3
API SM
OEM 07 51 0 037 195
Approved BMW Longlife-04 Oil Spec Used in:
BMW 335d E90 Chassis 2009-11
BMW X5 E70 Chassis 2009-13
BMW Oil - 5W-30 Weight - Motor Oil Spec BMW Longlife-04 - German Ravenol VMP - 1 Liter
BMW Oil - 5W-30 Weight - Motor Oil Spec BMW Longlife-04 - German Ravenol VMP - 5 Liter
BMW Oil - 5W-30 Weight - Motor Oil Spec BMW Longlife-04 - German Ravenol VMP - 5 Liter - Case of Qty 4
Blauparts BMW Categories:
BMW Shock Kits
BMW Automatic Transmission Fluid Filter Kits
BMW Motor Oil
BMW ATF Fluid
Check Out Our Other Sales and Specials!
Website:
See More Sales at www.blauparts.com
* Free shipping offers are for FedEx Ground shipping to 48 US contiguous states only. Offers End 11/30/2013
Ravenol of Germany is a proud technical partner of Robert Senkyr Motorsport Racing Team.
![](http://www.blauparts.com/assets/ravenolbmw1.jpg)
![](http://www.blauparts.com/assets/ravenolbmw2.jpg)
![](http://www.blauparts.com/assets/ravenolbmw3.jpg)
TroyE60
05-30-2019 05:01 PM
thesalboy
04-08-2015 09:13 AM
