Blauparts: 10% Off Factory Approved BMW Motor Oil Longlife-01 (LL-01) Spec
http://www.blauparts.com/eimages/for...mw_hcl_oil.jpg
10% OFF Select German Ravenol BMW Motor Oils + Free Shipping Use Coupon Code NOV1113 Offers End 11/30/2013 Ravenol HCL SAE 5W-30 Ravenol HCL is high performance low friction BMW oil with CleanSynto® fully syntheic technology. It can be used with gas or diesel engines with and without turbo-charging and direct injection. The formulation of Ravenol HCL CleanSynto® BMW motor oil reduces the engine's internal dynamic drag and can result in an 8% increase in fuel mileage, cleaner engine components, reduced engine emissions, maximum engine durability, reduced maintenance costs, wear and has excellent cold start characteristics. It is also suitable for extended oil change intervals where recommended by manufacturer. Factory Approval: BMW Longlife-01 Ravenol HCL SAE 5W-30 has received formal approvals from BMW in accordance with the BMW Longlife-01 oil spec. It also carries formal factory approved from Audi Vw for VW 502 00, 505 00 oil specs and from Mercedes for Mercedes Benz 229.5 oil specs. Read more about formal oil approvals here. Ravenol HCL Features: • Made In Germany • Improved fuel economy • Excellent shear stability • Excellent cold starting characteristics • Secure lubricating film in high operating temperatures • Excellent detergents and dispersant property • High wear protection • Prevention of foam formation • Extended lifetime because of oxidation stability • Excellent Viscosity behavior • ACEA A3/B4 • OE Reference: BMW 07 51 0 017 866 Approved BMW Longlife-01 Oil Spec Used in: All 2001 and present BMW gasoline engines. (Not to be used in M Series Model Or Applications) BMW Oil - 5W-30 Weight - Motor Oil Spec BMW Longlife-01 - German Ravenol HCL - 1 Liter BMW Oil - 5W-30 Weight - Motor Oil Spec BMW Longlife-01 - German Ravenol HCL - 5 Liter BMW Oil - 5W-30 Weight - Motor Oil Spec BMW Longlife-01 - German Ravenol HCL - 5 Liter - Case of Qty 4 Blauparts BMW Categories: BMW Shock Kits BMW Automatic Transmission Fluid Filter Kits BMW Motor Oil BMW ATF Fluid Check Out Our Other Sales and Specials! Website: www.blauparts.com * Free shipping offers are for FedEx Ground shipping to 48 US contiguous states only. Offers End 11/30/2013 Ravenol of Germany is a proud technical partner of Robert Senkyr Motorsport Racing Team. http://www.blauparts.com/assets/ravenolbmw1.jpg http://www.blauparts.com/assets/ravenolbmw2.jpg http://www.blauparts.com/assets/ravenolbmw3.jpg |
