Sonic Motorsports 1045 West El Camino Real Mountain View, CA 94040 tel: 650-733-6506 fax: 650-691-9009 email: info@sonicms.net Ksport Kontrol Pro Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 36 levels of damping adjustment allow you to fine tune the ride to your handling and comfort needs. The damping adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response. Where available, camber canbe adjusted via the Pillow-ball Top Mounts, which means no additional "Camber Kits" are needed. Most applications utilize an adjustable lower mount, which means you adjust height without losing suspension travel like some other coilover designs do. With the mounts and most pieces of the coilover being designed for 6061 billet aluminum the kit is lightweight, durable, and rust resistant. The steel shock body is electroplated with zinc to resist rust and the elements. The valving of each set is matched to the springs installed for unmatched ride quality and reliability. The Ksport system uses a Monotube design in which the oil and gas are separated within the cylinder. When compared to twin tube designs the Monotube dissipates heat better, allows finer damping adjustments, and requires more expensive design process. Aeration and cavitation are a lot less common in a Monotube design, which results in a better ride. The Ksport Kontrol Pro Coilover kit has been designed with professional road racing in mind offering extremely high value and performance. Features: - 36 levels of dampening adjustment - Monotube high pressure design reduces oil leakage - Pillow ball top mounts included for some applications - Camber adjustability is included on pillow ball top mounts - Made from high quality 6061 aluminum with T6 for increased hardness - Valving of each set is matched to the springs for ride quality and reliability - Electroplated body for protection from corrosion and rust - One year limited warranty through Ksport KSport's "Control" Coilover Package Contains - 4x coilovers (springs and shocks) - 4x brakeline mounts - 2x coilover wrenches - 2x dampening adjustment knobs - 1x instruction manual Additional Information - Spring Rates [kg/lbs] (Front - 10/560, Rear - 9/504) - Front utilizes Pillowball Upper Mounts, Rear re-uses OEM Download Owner's Manual (PDF) Applications: - E60/E61 (2004-2010) incl. 520/525/530 [MFG PN CBM111-KP] - E60/E61 (2003-2010) incl. 530/535/540/545/550 [MFG PN CBM112-KP] - E60/E61 (2004-2010) M5 (non-EDC only) [MFG PN CBM111-KP] MSRP Pricing: $1499/set For best pricing and ordering information, please call me at 650.733.6506, email at cal@sonicms.net or shoot me a PM. |
very nice setup here, mike sells these for $975 shipped, what are you offering them for ?
Actually this is a different model than what Mike is selling, or at least better than the one I have.
He said "Ksport Kontrol Pro". It's the same one that I got from Michael.
Oh..hm. Obviously I don't know what I have, plus I didn't really bother reading the thread.. fml..
I guess it is misleading if the stock photo's and the actual product are different. I definitely do not have the same model as the one's pictured is what I should have said... |
Originally Posted by PraiseTheLowered
(Post 1306724)
Originally Posted by redEYEjedi
(Post 1306783)
I guess it is misleading if the stock photo's and the actual product are different. I definitely do not have the same model as the one's pictured is what I should have said... https://img233.imageshack.us/img233/5229/img5539r.jpg |
acute does these for 950 think.
yea michael from acute quoted me 945 (shipped) so far hes got the best price
Just a quick note to all, we offer professional installation services with our certified technicians for customers local to the Bay Area. Please contact me directly for more information. :thumbsup:
