OEM BMW Oil
I decided to try out the OEM oil, instead of the Mobil One I've been using up to now. I must say, the engine does seem to run smoother and even the lifter noise is much lower now. Maybe it makes sense to use it after all? I'll keep you guys updated - I'm sending in a sample of my used Mobil 1 oil to the labs and will send a sample of the OEM oil when it gets worked out properly.
Unfortunately, Mobil-1 5w30 is not the recommended one. BMW recommends Mobil-1 0w-40 European Formula in the USA.
My Ride: See my signature
That's correct. Here is BMW's list of recommended synthetic oils for non M cars: http://www.bmwusa.com/Standard/Conte...ngineOils.aspx
<P align=left>BMW Long-life rating LL-01 Approved Synthetic Oils for the US Market:
- Castrol Syntec European Formula SAE 0W-30
- Mobil 1 SAE 0W-40
- Pennzoil Platinum European Formula Ultra SAE 5W-30
- Valvoline SynPower SAE 5W-30
Mobile 1 5w-30 has seen a big decrease in quality over the year(at least in oil terms).
Mobile 1 0w-40 is pretty good quality. Though as another user stated that it does run thin which can cause slightly more engine noise. I've noticed this slightly when I use Mobile 0w-40.
BMW's oil is Castrol's European formula repackaged. If your dealer isn't doing crazy mark ups they cost about the same as the Castrol stuff at an Auto Store.
