Vacuum Pump Oring Leak fix
Old Jun 5, 2010 | 10:37 AM
Rummat81's Avatar
hello, the Oring behind the vacuum pump on my 04' 545 was leaking. I got the Oring from my dealer, the part # 116675509080.
The vacuum hose at the top and front has to be removed and the brackets holding the power steering and coolant lines have to moved sway to make enough room. The Flat screwdriver like flap slides into a slot and get rotated by the camshaft while engine is running. no leaks now. pics attached.
It takes about 30-45 mins at a leisurely pace.
NOTE: the 3 bolts that attach the vacuum pump to the head are a special TORX type # 6 size. you can check that bolt in the last pic. make sure you have this socket before attempting this. i also got an extra bolt in case i stripped it.
Attached Thumbnails Vacuum Pump Oring Leak fix-dsc00049.jpg   Vacuum Pump Oring Leak fix-dsc00050.jpg   Vacuum Pump Oring Leak fix-dsc00051.jpg   Vacuum Pump Oring Leak fix-dsc00053.jpg   Vacuum Pump Oring Leak fix-dsc00054.jpg
Old Jun 5, 2010 | 10:48 AM
e6t.lab.rat's Avatar
Nice DIY! Congrats on the fix and thanks for posting part #'s. I guess our 545's are notorious for this type of repair because it appears I may need to be changing mine (oring also) soon. Thanks
Old Jun 6, 2010 | 09:01 AM
turboawd's Avatar
My Ride: 2006 BMW 550i
are you positive the o-ring on the rear of the pump was leaking?
usually the o-ring under the front cover of the pump losses its shape, and starts leaking.
Old Jun 30, 2010 | 01:14 PM
blackfalcon's Avatar
My Ride: 2005 545I SMG. 2006 Nissan Titan SE. 2006 Daytona 675. YZ250F. John Deere 2520.
How did you know that this was leaking? Ie what are the symptoms?
Thanks.
Old Jun 30, 2010 | 10:04 PM
turboawd's Avatar
Thanks.
you'll see a dirt/oil film under the pump. and if it leaks enough, you'll have oil dripping on the belly pan.
Old Jul 1, 2010 | 12:38 AM
Rizbel's Avatar
My Ride: 545i Sport
+1. Thanks .
Old Jul 28, 2010 | 12:40 PM
Howitzer's Avatar
Talked to my dealership wondering if same problem happens with the 530. Anyways, they say this pump for the 545 costs $460 retail from the dealership. Not cheap.
Old Jan 22, 2011 | 10:41 AM
545felix's Avatar
My Ride: 05 545/6
where does the vacuum line that plugs into the small connection on the front of the pump lead to? I had to cut the end off that hose and reattach it this morning as it was cracked. just wondering if that was causing my fluctuating idle when the car is cold.
Old Mar 5, 2014 | 12:20 PM
Munki's Avatar
My Ride: 545i, 07' gallardo, 12' s65
Anyone? Im replacing my pump and I noticed this line wasn't even connected...
turboawd
Aug 23, 2017 12:27 AM
Lboy
F10 Discussion
Aug 8, 2015 08:39 PM
Yas1083
May 12, 2015 12:46 PM
TexaZ3
Apr 8, 2015 10:50 AM
NickP
Jul 15, 2004 11:18 AM
