Service Due! How do I reset this?
Old 04-28-2010, 01:48 PM
beemerkid23's Avatar
My '08 528i just reached 50k miles so I just changed oil & filter, and air filter. All genuine BMW parts. Can someone show me how or is there even a way to reset the "Service Due" icon that blinks everytime I start up my car without bringing it to the dealership since it is out of warranty.
Any info would be greatly appreciated.
Old 05-03-2010, 05:02 AM
melimel's Avatar
bump for an answer hopefully..lol
Old 05-04-2010, 10:45 PM
ntpcrew13's Avatar
My Ride: e90 / 330i / arctic / black leather / burl wood trim / steptronic / premium package / cold weather package / navi-idrive / sirius sat radio / 60 gig black video iPod in the aux / bluetooth with iPhone / hard-wired Valentine 1 v1.8 / KW V2 / blacklines / tvandnav2go / half din dvd player / reverse camera / alpine type R 12" sub with RF amp / LED turn signals / bastuck exhaust with SR eisenmann pipes / gruppe M rep intake / 2003 - e53 / x5 / black / black leather / burl wood trim / steptronic / premium package / cold weather package / navigation / 6 disc cd changer / hard-wired Valentine 1 v1.8 2002 - G20 / infiniti / titanium silver / grey leather / automatic / premium package / cold weather package / sports package / 6 disc cd changer / cordless escort solo 2000 - Frontier / nissan / alpine white / grey cloth / automatic / crew cab / white cap
this was written by kev525
Firstly with the ignition switched on, set the odometer trip meter back to zero by pushing it once. Then switch the ignition back off again. (I found this step was critical, otherwise I couldn't get to the "Service" menu).
Now you are ready to go through the reset steps as follows:
1. Switch the ignition on (so that the battery, Oil and Parking brake lights are displayed) and the key is ready to start the engine - but don't actually start the car.
2. Press the odometer reset button for between 5 and 10 seconds until a yellow triangle with an exclamation mark in the centre appears in the top window between the clocks (where the outside temperature / time or date normally appears) - this is the "Service" icon.
3. Release the odometer button briefly and press again straight away which brings up a picture of the Brake Fluid symbol (same as the one that the i-drive shows when you look at the Service menu).
4. If you want to reset the Brake Fluid interval for another 2 years then keep holding the odometer button until the word "RESET?" appears at the bottom of the lower window.
5. Release the button briefly and push it in again and hold for about 5 - 10 seconds until the new date appears in the bottom window. You can then switch the ignition off and the new Brake Fluid date will appear in the service menu on the i-drive screen next time you switch on.
6. If you want to reset the Oil, Microfilter or Brake Pad indicators then you will need to follow the same sequence as steps 1 and 2 above, but when you get to step 3 and the brake Fluid icon appears, just release the button and press again and the next service item will appear.
7. You can continue releasing and pressing the button until the required service item icon appears for the one you want to reset. As soon as it does then hold in the button in until the word "RESET?" appears again as in step 4 above. Once the word "RESET?" has appeared, you need to release the button briefly and hold it in again for about 5 - 10 seconds until it is replaced by the new service interval figure (as per step 5 above).
Hints & Tips
Before actually resetting anything, go through steps 1, 2 and 6 above until you are familiar (and sure) what you want to reset. Practice this a few times and note down in what order the icons appear after the initial "Service" icon appears.
If you do happen to hold the button down too long against an item you don't want to reset and the "RESET?" appears, just leave the button alone for 10 seconds or so and it will not let you reset the item. (Alternatively just switch the ignition off and start again).
Sometimes if you have not released and pressed the button again quickly enough, when you hold it down again the German technical writing will appear after about 15 - 20 seconds instead of the Service item icon you were expecting. (If this happens just switch off the ignition and start again).
Once you are sure what item you want to reset and are confident of the sequence, then give it a go. If you do hesitate between releasing and pressing the button at any time, you will have to go back to the beginning and start again as "he who hesitates is lost".
It took me a while to get the hang of it and I'm sure it'll take me a while to get my head around it again next time.
Let me know how you get on.
Old 05-07-2010, 11:27 AM
Thanks guys, I'm trying it later.
Hints & Tips
Old 06-14-2010, 05:23 PM
This doesnt work for my 2008. The idrive is a bit different on the newer models. I think that only applies to the 04-07 e60's.
Still outta luck.
Old 06-16-2010, 12:16 PM
turboawd's Avatar
My Ride: 2006 BMW 550i
really?
are you looking at the display on the dash between the speedo and tach? holding the trip reset button?
nothing will show up on the idrive screen when doing this.
Old 06-16-2010, 04:49 PM
tex_phil's Avatar
My Ride: 04 525i, 04 Dinan M3
I just did this after replacing my brake pads and now it shows -15,000.
How can I fix that?
Old 06-16-2010, 10:39 PM
turboawd's Avatar
How can I fix that?
did you replace the brake pad sensor?
Old 06-17-2010, 08:33 AM
tex_phil's Avatar
Yes
Old 06-17-2010, 10:33 AM
turboawd's Avatar
Yes
i replaced my rear pad before they hit the sensor, and reused my old sensor, and reset the computer. no problems.
you and a few others have had this -15000 problem, and i thought it was just that the sensor needed replacement. let us know what you find out.
Quick Reply: Service Due! How do I reset this?
