▀▄ eas - mObridge DA1000 MOST Preamp for BMW - $699
Old Mar 15, 2010 | 04:28 PM
tom @ eas's Avatar
The mObridge preamp is designed to seamlessly integrate into the MOST bus system and interface into the audio digital data stream to allow any aftermarket amplifier to be added to your audio system without the need to use "HIGHtoLOW" audio converters. The mObridge preamp interface operates on a digital level and does not introduce unwanted noise levels and harmonic distortions that an analog converter hooked into the existing wiring of the vehicle would give you. The piece connects into the MOST bus vehicle system without having to cut into the speaker wiring of your premium vehicle.
The mObridge preamp gives the user complete control over volume, fade, balance, treble, bass and equalization settings. Utilizing a state of the art powerful 400 MHz Digital Signal Processor, the mObridge preamp is able to take advantage of the digital domain space and provide the user with complete control for the existing vehicles interfaces such as the BMW iDrive.
Specifications
- Digital SP/DIF TOSLINK output
- High performance Digital Signal Processor
- Volume, Bass, Treble, Balance, and Equalization control
- External Amplifier power control
- SD card user settings file
- SD card firmware upgradeable
- Single unit is configurable across multiple vehicles
- Seamless Audison Bit One integration
Compatible with the following vehicles
2008+ e8x 1-series
2006+ e90 3-series Coupe, Sedan/Touring & Convertible, including M3
2004-2008 e60 5-series, including Touring & M5 *
2004-2008 e63/e64 6-series, including M6
2004-9/06 e65/e66 7-series
2007-2008 e70 X5
2007-2008 R56 Mini Cooper Coupe
2008-2008 R55 Mini Cooper Clubman
2009-2008 R57 Mini Cooper Cabriolet
Notes: Requires activation from BMW or MINI dealer after installation if not originally equipped with LOGIC7 or Enhanced Premium Sound sound system. e60 5-Series M-ASK iDrive (04-06) model compatibility will be arriving in Summer 2010.
mObridge - DA1000 Preamp for BMW
http://www.europeanautosource.com/pr...oducts_id=3124
For local members, installation/coding is available in-house.
Old Apr 30, 2010 | 11:44 AM
cleung's Avatar
this would be nice to have if it was about $300-$400 cheaper, considering you need the bit-one which is another $700 but you can use the bit-one without the mobridge.
Old Apr 30, 2010 | 07:52 PM
nelson29's Avatar
+1k I remmember when i was waiting for it to come out, Mobridge had estimated a $300-$400 street price.
Old Jun 15, 2010 | 02:36 AM
Nick71's Avatar
Why don't consider this italian solution http://www.motuslab.com/en/productsa...iogateway.html
TroyE60
May 30, 2019 05:01 PM
i6YouNot
May 19, 2015 02:40 PM
JonathonK
Mar 27, 2015 08:13 AM
carid
Mar 27, 2015 04:47 AM
reckamech
Sep 8, 2003 01:24 PM
