Need help removing mtech bumper
Old Jan 25, 2010 | 10:26 AM
mag75's Avatar
Ok - I am finally giving up and asking for help after searching and not finding all the help I need.
As the title says, I need help removing a mtech bumper....the only directions I have are to remove the stock bumper, not a mtech...can someone help out?
Here are the stock bumper directions: https://5series.net/forums/index.php?showto...mp;#entry326061
So, all I know to do right now is to remove the 5 bolts on the top of the bumper as the mtech and stock are the same in this regard.
So, what is the next step? Also, is this rather difficult and if so, should I get a professional to do it?
Thanks !
This is all I know right now, what is next:
Old Jan 25, 2010 | 01:42 PM
mag75's Avatar
I am not trying to bump this thread but I could really use some help....has anyone installed a mtech bumper that could tell me where all the bolts and/or clamps are? I really have no idea where to start after removing those 5 bolts.
Old Jan 25, 2010 | 03:34 PM
08white's Avatar
My Ride: 2008 BMW 535XI white
i dont have Mtech, but i think it should be same
5 bolts on top (above grill), 2 below (lower grill), 3 on each side of wheel wall
Old Jan 25, 2010 | 06:18 PM
mag75's Avatar
That is what I was thinking but was wondering if anyone had a little more detailed instructions......ie where the bolts were etc and if is was difficult.
Old Jan 25, 2010 | 09:04 PM
turboawd's Avatar
My Ride: 2006 BMW 550i
the mtech bolts on almost the same as the stock bumper. use the instructions you linked in the other thread.
i believe that there are only 2 bolts in front instead of 4, on the mtech.
it not very hard. probably the hardest part is sliding the bumper out from the fender. there is a plastic piece on the fender that holds the bumper.
read this thread, and click on his installation link: https://5series.net/forums/index.php?showto...0&hl=m-tech
Old Jan 26, 2010 | 05:55 AM
mag75's Avatar
Thanks...So I imagine the two bolts you are referring two are located behind the fog lights? Based on the picture below, this appears so.....
Old Jan 26, 2010 | 11:22 AM
turboawd's Avatar
actually, the 2 screws are on the top side of the center air intake. you'll see them when you go to take it off.
Old Feb 1, 2010 | 07:47 AM
mag75's Avatar
Ok....well I removed the bumper this weekend. Since I never really got any good directions, I thought I would create a DIY for those down the road...hope it helps.
https://5series.net/forums/topic/932...umper-removal/
tnycman
Jun 17, 2015 11:35 AM
Nickalitis
May 18, 2015 07:48 PM
ianmosiah
Apr 22, 2015 01:01 PM
blackstarr
Mar 5, 2015 04:54 PM
rkilpa
Mar 4, 2015 09:10 PM
