Trunk Release Opening too quickly
Old 01-25-2010, 08:30 AM
sessionmc's Avatar
My Ride: 2004 545i Sport
2004 545i US
Recently Purchased. Great car. Only thing I noticed is that the trunk release opens much MUCH faster than my previous 545i. It seems its hitting way too hard at the top-end causing me to always use my hand to dampen the impact.
Searched and couldn't find anything about it but I remember reading something similar on the forums earlier.
Any Solutions?
Old 01-25-2010, 08:33 AM
Anzafin's Avatar
My Ride: Bmw 530d 2004
Originally Posted by sessionmc' post='1097555' date='Jan 25 2010, 07:30 PM
2004 545i US
Any Solutions?
You can adjust it by changing the attaching points of the springs that bounce the trunk up.
Old 01-25-2010, 08:47 AM
sessionmc's Avatar
Im not really sure where those are located.
Old 01-25-2010, 08:54 AM
Anzafin's Avatar
Remove the left/right side covers in trunk and you'll see the springs. There are two plastic "screws" on both sides holding the cover in place. Turn the screw 90? and pull it out. Then you can lift the cover panel off.
Old 01-25-2010, 09:19 AM
sessionmc's Avatar
ok Thanks a bunch. Ill check it out when it stops raining.
Old 01-25-2010, 09:26 AM
vlad_b's Avatar
mine does the same thing. and I saw were those springs could be adjusted. I wonder how it can be done DIY with out hurting myself (tension of the strut is high)
Old 01-25-2010, 09:31 AM
Anzafin's Avatar
Maybe the easiest way is to remove the rear light so that you can access the spring straight from behind with some kind of a hook and pull it with force.
Old 01-25-2010, 11:03 AM
EBMCS03's Avatar
Get a trunk finisher... it'll add weight to the rear and make it look better.
Old 01-25-2010, 11:15 AM
Anzafin's Avatar
Oh that is true!
A week and half ago when I had to remove my trunk finisher for a repaint I noticed the trunk lid lifted much much quicker without it (the finisher).
Old 01-25-2010, 11:32 AM
Greenberg's Avatar
Originally Posted by Anzafin' post='1097701' date='Jan 25 2010, 11:15 PM
Oh that is true!
lol I guess that why I dont have same problem *looks at his OEM M5 spoiler*
Quick Reply: Trunk Release Opening too quickly
