E61 LCI Lights with V6 Bruce Miranda Cables
Old 05-17-2009, 02:28 AM
kErb's Avatar
My Ride: 2005 E61 525d M-Sport, Titanium Silver, Black Dakota Leather, Media Pack, Sun Protection Glass, M6 Staggered Alloys, ACS Rear Diffuser, EBC Green Stuff Brake Pads, I-Pod Interface. Rear Aux Power DIY, LCI Rear Lights, Extended interior lights - doors and footwells, LED licence plate lights.
Exclamation
The new V6 versions of Bruce Miranda's LCI light cables have arrived. They look fantastic, and were fitted using the same bracket as the E60, albiet in a slightly different position.
To give sufficient clearance on the light; the bracket was slighty modified by elongating the holes to allow me to attach the bracket to the V6 in the corner position.
There are only three threaded location points on the E61 lights and I needed to use the upper / inner position nearest to the tailgate. The fixing location is shaped into a recess which mean't that the bracket would't sit flush, so I had to put some packing behind the bracket first. I used a plastic number plate nut which was just the right size and then secured the V6 in position, using the standard nut.
The installation was completed yesterday using ArneR's excellent DIY procedure - LCI rear lights on pre LCI E61, How to do it with Bruce Mirandas cables.
The outer lights are a doddle, and the tailgate lights are okay, you just need to take your time and be methodical.
Bruce was extremely helpful and assisted in allowing me to choose the position of the brake light bulb that would illuminate. I understand that the E60 lights use the inner bulb with the outer bulb used for BFD.
My personal preference due to width of the light was to use the outer position.
I bought the outer lights from EBay and Bruce was even able to supply a connector for the back of one of the lights which was broken when they arrived. BMW said I'd need a new light!! Thanks Bruce you certainly know your stuff.
[attachment=10247251600311.jpg]
Then just to finish off I then changed the number plate lights to LED, again using Bruce's magic cables.
Before:
[attachment=10247351600261.jpg]
After:
Old 05-17-2009, 02:30 AM
Patrick E61's Avatar
Nice!
Do you a pic of them installed? I mean the cables... I don't have the brackets yet, and I would like to see how you installed them!
Old 05-17-2009, 02:31 AM
LOL. The last pic was not there when I replied!
Old 05-17-2009, 05:23 AM
kErb's Avatar
Originally Posted by Patrick E61' post='880867' date='May 17 2009, 11:30 AM
Nice!
Patrick
If you need some more pictures please let me know.
kErb
Old 05-21-2009, 08:37 AM
ArneR.'s Avatar
Looks great KErb
Old 06-26-2009, 12:54 AM
Utini27's Avatar
Looks very nice, can you give me a quick hint to the number plate LED cables you mentioned?
Searched the forum but only found the DIY solution.
thx!
Old 06-26-2009, 12:58 AM
keith84_uk's Avatar
My Ride: BMW E60 530i , Silver with leather Air Con iDrive 17" Breyton Rims with Dunlop Sp Sport tyres (M-Tech Bodykit and rims WANTED) Alfa Romeo 147 TS1.6 , Black with Air Con 17" Multi Spoke alloys with Bridgestone RE040 tyres Toyota MR-S 1.8 VVTI , Lagoon Blue with Red leather Air Con 15" standard alloys with Toyo tyres Toyota Celica 1.8 VVTI, Lagoon Blue, Air Con, 16" Standard alloys with Kuhmo KU31, EBC Green Stuff
Very nice!!
Love the LCI lights
Old 06-26-2009, 11:23 PM
Ellicit's Avatar
look really good... can you post some pox of your car... I never saw a wagon with Mtec
Old 06-27-2009, 04:41 AM
kErb's Avatar
thx!
Thanks for your comments - I'm really pleased with how the LCI lights look.
The licence plate LED's are as per this link http://forums.e60.net/index.php?showtopic=63536. I bought the cables from Bruce Miranda, and they are a direct plug and play item with the BMW LED number plate light part number 632 6719 3293.
I've had a couple of problems with the I-Drive errors on my E61, and Bruce is currently working on a solution for me. For some reason my car is super sensitive, but I'm confident Bruce will come up with a fix.
Old 03-05-2011, 03:31 AM
jbautista7272's Avatar
Hello. I have an E61 like you and I bought the Miranda Bruce adapter to change the rear lights to new LED. I changed the rear lights outside and look great, but I wonder how you've changed the drivers door, the interior? Has it helped Miranda Bruce adapter or you had to buy a new adapter? Please help me
Quick Reply: E61 LCI Lights with V6 Bruce Miranda Cables
