extra wire under rear seat
My Ride: 2006 BMW 550i
Originally Posted by gblass' post='860024' date='Apr 27 2009, 12:18 AM
Possibly for heated rear seats?
It's just a guess.
It's just a guess.
rear seat removal instructions:
yank up on the front edge of the seat. there are 2 clips holding it down.
after you lift the front a little bit, slide the seat forward a little. then you can lift it up. if you have rear seat heaters, you must disconnect those wires before you can lift the seat up all the way.
to put the seat back in, align the seat belt buckles with the holes in the seat, slide the seat bottom underneath the seat back. then push down on the front edge of the seat to snap the clips back in place.
The wire is most likely the one for the battery switch that is only used when the car is being transported from the factory to the dealer...
http://forums.e60.net/index.php?showtopic=9299
and my wire was sticking out from under the seat also, like others had said.
socale39
09-05-2023 08:30 AM
