Replaced spark plugs on N52(2006 530i)
Old Nov 7, 2008 | 02:47 PM
bitboy's Avatar
My Ride: 530i 2006 Jet Black w/tan leather. Premium package; Sport Package; Sat Radio
I have been getting an irregular idle on my 2006 530i for the past month. I tried the fuel additive without any luck. After seaching this site, I noticed several folks had replaced their spark plugs to fix the problem. I didn't see the process documented so I thought i would add to the knowledge base.
Replaced: 6 NGK BMW spark plugs with same type
Engine: N52 Inline 6
Model/year: 530i/2006
Miles on car: 55k
Difficulty level: Pretty easy
Time it took: about 1 hour
Step #1: Remove acoustic engine cover(see attached PDF)
Step #2: Remove Micro Filter and Micro Filter base. I didn't take any pictures while it was being removed but i did include a picture showing the location(see attached PDF). It is only attached by 3 plastic bolts and one hex bolt. You need to remove this to get to the last two spark plugs. (you only need to remove the half that is over the spark plugs
Step #3: Remove spark plug wires connection from ignition coil. This is a little tricky and if you are not careful you will pinch your finger(see attached PDF)
Step #4 Remove ignition coils. It took a little twisting and pulling to get them out
Step #5 Remove Spark plugs. I used my 3/8 socket wrench with a long extention and a 5/8 spark plug socket with U-joint
Step #6 Install spark plugs. Make sure you put the anti-seize stuff on the threads. BMW does not sell it but your local auto store should. The guy at the BMW part store told me to tighten them to 19 Foot Pounds.
Step #7 Install ignition coils. Make sure they are positioned correctly(see attached PDF
Step #8 Replace micro filter/base as well as the acoustic cover
That it and it fixed my problem!
Sorry I didn't have pictures with each of the steps. I hope this helps.
Old Aug 27, 2009 | 09:29 PM
tex_phil's Avatar
My Ride: 04 525i, 04 Dinan M3
Thanks for the DIY!
Old Aug 27, 2009 | 10:15 PM
v_therussian's Avatar
Think I'm gonna get mine done just for kicks either this or next weekend...
Old Aug 27, 2009 | 10:22 PM
NoName545i's Avatar
My Ride: 2004 BMW 545i Sport Package, Titanium Gray II Metallic, Wheel Style 124
look for better gas mileage =0)
Old Aug 28, 2009 | 03:38 AM
530inOK's Avatar
My Ride: 540i
Model Year: 2017
I'm glad this DIY resurfaced.
Old Aug 28, 2009 | 07:47 AM
AKAlius's Avatar
Thanks for the DIY!
Old Oct 1, 2009 | 12:54 PM
baronson's Avatar
Originally Posted by AKAlius' post='991431' date='Aug 28 2009, 10:47 AM
Thanks for the DIY!
Did you replace the aluminum screws?bolts like it says in the Tech sheet.
Old Nov 19, 2009 | 09:33 PM
jfishburn's Avatar
Just completed the swap without removing the microfilter. Trick is finding the right length extension. Job complete in 30 minutes!
Old Nov 24, 2009 | 11:41 PM
pinguhk's Avatar
My Ride: Mini Cooper
that for the write up I will change my pulstar when I get my car.
Old Nov 29, 2009 | 02:48 PM
BET530's Avatar
My Ride: 2006 530i
what spark plugs brand is the best choice for our engine???
